Old 01-03-2014, 12:19 PM
Default Raising floor
What is the reason when rebuilding seacrafts everyone says to raise the floor.
Old 01-03-2014, 01:07 PM
so the deck will self bail and be above the water level
Old 01-03-2014, 07:12 PM
Mike
Give me a call.
Thanks
Old 01-03-2014, 02:27 PM
parrott parrott is offline
Dont buy a "redone" one that has not had the floor raised. Unless you want to keep plugs in it all the time.
Old 01-03-2014, 07:10 PM
Back when these older Seacrafts were built, the only motors were 2 strokes and they are lighter than the 4 strokes. Adding the additional weight of the four strokes requires the floor to be raised to keep the cockpit self bailing.
Height usually depends on if you are putting 2 motors or 1 back on.
Old 01-03-2014, 11:44 PM
There are some who might say that the answer is a motor that has an appropriate weight, and movement of batteries, tanks and such to re-establish balance rather than raising the floor. It can be done, and in my opinion, it is easier than raising the floor.
Old 01-03-2014, 11:55 PM
X2 on that. Also adding a Hermco fiberglass "floatation" bracket can help too.
Old 01-04-2014, 01:49 PM
Really limits your choice of motors especially if going new.
Plus most of the Seacrafts we have done needed the floor replaced anyway.
I can raise the floor a whole lot cheaper than buying and installing a Hermco bracket
Old 01-04-2014, 06:54 PM
I agree 100%! Keeping the boat's CG where it was designed to be is very important to overall boat performance, ride and handling and just as important as keeping your feet dry if not more so! Plus the SF models don't have a whole bunch of freeboard to start with - I prefer to have the gunnel at or above my knees, not down around my ankles!
Old 01-04-2014, 07:35 PM
Don't you think ankles is a little extreme. Haven't done one yet that was uncomfortable leaning against the gunnels.
Plus raising the floor a couple inches isn't going to affect the ride (CG)as much as installing brackets and moving tanks around.
The first question I always get when selling one of these restores is "does it self bail"
