Old 01-04-2014, 08:57 PM
Big fish Big fish is offline
Default How reliable are the newer engines?
Seems like all 20 footers run single engines without any kicker. Are the 4 stokes and newer 2 strokes very reliable? Does a lot have to do with weight issues? My 20 sceptre came with twin vro 60's. I'm thinking of upgrading and not sure to go twin or single. Any advise would be greatly appreciated.
Old 01-04-2014, 11:24 PM
I have an older Yamaha F100 on my 20MA (same as a F90, with higher RPM limit). I also have a 30" shaft tohatsu 6hp SailPro kicker. Both 4 stroke. Weights are 367 and 58 lb, respectively. I wouldn't put more on a stock 20" transom. But I love the security. I have a 20 gallon tank for the F100 which gets 5? MPG and 6 gallon portable tank for the kicker. I like the combination. Batteries and tank are under my console. I am way more comfortable off shore with a kicker. It will charge a battery, too.
A second 6gallon tank is a nice get you home margin on a 5MPG main engine. And a 5 gallon Jerry can is 25 more miles. Ballasted wherever you like.
Old 01-05-2014, 01:24 PM
I have over 500 hrs on my E-TEC and have had zero reliability problems; starts instantly on the first revolution every time! Although the boat is just barely self bailing with the big Hermco bracket, at 429 lbs, I sure wouldn't go any heavier on the motor for balance reasons, especially with a bracket. Took it on a 700 mile trip in 2010, loaded very heavy with 2 coolers, gear, groceries, and extra gas jugs, averaged about 4.5 mpg, cruising at 27-31 mph.
Those I-3 60's were much lighter than any of the new motors, so I wouldn't recommend any modern motor for twins because of weight, but all the modern moters are very reliable so I wouldn't worry about a single. A single plus a small kicker is also a viable option, since with twin 4-strokes, you probably wouldn't have enough mid-range torque to plane on one engine anyway! The 2.6L V-6 E-TEC (135, 150, 175, 200) is PLENTY of power for a 20, but even the 115/130 HP V-4 is more than enough power if you run in rough stuff a lot, and the boat will ride better and plane at lower speed with almost 50 lbs less weight on the transom!
Old 01-06-2014, 09:43 AM
1700 hours on a 2004 df250 4 stroke that has never left me stranded. Put your money in a towboat us or seatow policy and a sat phone. They will come to you if by some remote chance you have an issue. The policies are cheap because their risk is low.
You also have to consider the statistical likelihood you will have a failure very far offshore. Set aside the chances are very low for any failure to consider your best chance for a failure at your furthest destination is at 30% of that. If you're taking your 20 footer 50+ miles offshore you are way more likely to have an environmental problem than a mechanical one.
For those who enjoy the security of additional kicker engines, I have a nice honda 8 hp in long shaft perfect for the job. It will never end up back on my rig again so it is available for any interested.
Old 01-06-2014, 09:51 AM
fdheld34 fdheld34 is offline
Ken....might be interested....is the 8 hp honda a 2 stroke???
I am running a 1990 Looper so obviously need two stroke unless I run seperate tank for the kicker if it is 4 stroke...
P.S. your windshield worked out great Thanks again!
-Fred
Old 01-06-2014, 10:43 AM
The honda is a 4 stroke. Glad it worked out. Still have lots of misc. Sceptre/Tsunami parts I may consider bringing to the next gathering.
Old 01-07-2014, 02:12 AM
Thanks for the input guys. I'm just worried about getting stranded with a single. And I'm not sure if we have that type of insurance in hawaii. What do you think about the yamaha 70's? Weight is 257 pounds each. I'll be adding a bracket and it's only about 54 pounds heavier than my 60's.
Old 01-07-2014, 09:28 AM
I looked at that option and came to the conclusion it is too heavy. Fr. Frank can weigh in on 20 footers rigged with small twin 2 strokes like yours. But twin 4 strokes is pretty heavy.
My 14 year old Yamaha hasn't stranded me yet- the kicker rarely gets used, but it does push the boat along well and is nice for trolling. When I have money, I will get a Teleflex SEASTAR (not Baystar) hydraulic steering so I can steer the kicker from the helm with the add-on.
Old 01-07-2014, 01:54 PM
cdavisdb cdavisdb is offline
Funny Moose should mention a sat phone. I was looking at buying one an hour ago.
Old 01-07-2014, 02:52 PM
Boat U.S./Vessel Assist operates out of Honolulu and Kona. For a $150 annual membership they'll fetch you at no additional cost 50 miles from the coast. if you're 10 miles farther out you only ante up for the 10 mile tow to the 50 mile mark. The balance is covered.
I don't think I'd put 500 lbs of twins on a 20' sink-craft. Maybe with a twin flotation bracket like Hermco's. Otherwise, no way. Single modern motor is pretty dang reliable and fuel efficient. Add a stow-able kicker until you trust your motor, and vessel assist, and you're golden.
Always having had older boats and motors, I can't say enough about Vessel Assist. Best $150 I spend every year whether I call them or not.
