Old 01-09-2014, 05:51 AM
Beaver Beaver is offline
Default 18 Bow Eye
It appears that the bow eye on my boat is coming loose or pulling through (ie. there is a lot of threads showing).
It also appears that to fix this I am going to have to cut a hole through the liner in my fish box. Has anyone done this before? Any recommendations on the best way to do it? I was thinking about a hole saw but I am afraid the guide bit may punch through the hull.
Thanks for any suggestions.
Rob
Old 01-09-2014, 04:24 PM
id try a shorter but in the hole saw to stred the circle cutting, then perhaps remove the bit and just cut with the hole saw slowly
82 seacraft 20SF
Bayview Canvas
Old 01-09-2014, 07:33 PM
76Red18 76Red18 is offline
Had to do that. I used a 4" grinder with a diamond blade. The original eye only had small washers and dug into the glass. The new one I used has a small backing plate.
J. M. Hendrix
Old 01-09-2014, 08:29 PM
sidelock sidelock is offline
You should be able to access the bow eye nuts from the anchor compartment and not have to cut any holes. Mine has a small removable piece of plywood in the bow anchor compartment and once removed the nuts are visible & accessible.
Old 01-11-2014, 12:56 AM
I think I am going in with the 4" grinder. Thanks for the feedback.
Old 01-11-2014, 08:29 AM
These work really well!! I've got one I used on my boat and it's really easy to set the depth to cut only as deep as you need.
http://www.dremel.com/en-us/tools/pa...0#.UtE4ffRDvNk
Old 01-11-2014, 02:48 PM
Good call Don. The last thing I need is big hole in the front of my boat. Thanks for the tip. I am going to get into this weekend.
Old 01-15-2014, 01:35 AM
Told you guys that DonV was a smart sum bitch
Old 01-15-2014, 11:26 AM
I see the 'ol ESD could not sleep last night!!!!
Old 01-15-2014, 03:27 PM
What-cha talkin' bout Willis.....
That's when he gets up!!
