Old 01-30-2014, 11:19 PM
verch verch is offline
Default Steering replacement needed
I'm considering replacing the steering system in my 20'. It looks like the SeaStar Big-T system and there is a bit of slack in it. I'm open to advise on replacement recommendations and repair suggestions. I purchased the boat a couple months ago for $10k and I'm in it now for about $13,500 after rewiring, rebuilding the console, adding GPS, replacing gauges, etc. etc. I'm about to paint the topside now and I don't want to spend another $1,000 on steering so I'm looking to stay with a mechanical system. Any thoughts?
Old 01-31-2014, 01:57 AM
Presumably you've confirmed that the culprit is not just a stretched out cable. Those rotary helms are pretty tough.
Old 01-31-2014, 08:25 AM
you can come in well under 1K for hydro steering if you shop around on ebay and craigslist. well worth it.
Old 01-31-2014, 11:36 AM
fdheld34 fdheld34 is offline
I would also check cable first like Gille suggested
but
If you decide to go hydraulic...
Go Teleflex Baystar hydraulic steering if your 150 hp or under
here is a link from ebay for starters
http://www.ebay.com/itm/TELEFLEX-BAY...7819db&vxp=mtr
Old 01-31-2014, 12:46 PM
I'm not sure how to check the cable but I plan to look over it this weekend to be sure that all fittings are properly tightened. How would you recommend checking it? Is hydraulic really that much better? I've never driven a boat with hydraulic steering.
Old 01-31-2014, 01:37 PM
Boatboy6 Boatboy6 is offline
You haven't lived
Old 01-31-2014, 06:11 PM
Agreed, hydraulic is a night and day difference..i just went with Uflex over Seastar
Old 01-31-2014, 11:09 PM
Okay.. You have my attention. I don't think I'm even gonna screw with the old system. The new hydro systems look pretty easy to install and look like they will be much more enjoyable. I appreciate the tips.
Old 02-01-2014, 09:26 AM
I purchased the seastar system that fdheld34 provided the ebay link to. Any tips on the installation?
Old 02-01-2014, 10:39 AM
Good choice! You won't regret not having to fight the wheel all the time. All I can think of is make sure all your connections are tight and make sure to bleed the system correctly.
