Old 02-07-2014, 09:10 PM
Default Am I missing anything?
Haven't seen bluewater in 5 years. Taking the Sceptre 50 miles offshore. Replaced floor, new 160g tank, twin 150 oceanrunners, rebuilt carbs, fuel pumps, shift boxes and water pumps. All new fuel lines and water seperators. New gps and VHF. Bracket on boat. Floscan working(16gph cruise). I need an epirb. I just need triple checking and extra heads always help. Thankyou. Of course rods and cold ones! New wiring included also along with bilge pump.(1)
Old 02-07-2014, 09:38 PM
martin martin is offline
You need more then 1 bilge pump. Depending on temp of wayer...i like to have a couple of gumbi suits.. Live bait??.
Old 02-07-2014, 09:42 PM
Inflatable PFD's, float plan, fishin' buddies...
Old 02-07-2014, 09:49 PM
tautog_33 tautog_33 is offline
Don't know which coast your leaving from, but consider a life raft, sat phone, and SSB radio. Epirb without a doubt.
Old 02-07-2014, 10:27 PM
No, trolling small lures and possibly live bait if I can find it. Water temp in the high 60's by now. Will go out in tandem first time also. Inflatables will be on boat. I like nice jackets also. Float plan? Definitely north! Really, I didn't mention ALL the details but this time of year typically there are other boats close.
Blackfin tuna. Worse case fuel burn should be 1.0 mpg. I will add that second bilge though. I did install a 1500gph pump but if one were to fail....
Old 02-07-2014, 10:28 PM
Leaving from Edisto, South Carolina. 50 miles to ledge.
Old 02-07-2014, 11:01 PM
Good luck on your trip! Catch some BIG ones...
Old 02-08-2014, 09:28 AM
castalot castalot is offline
Float plan:
Who you are
Where your going
When your expected back
Who to contact
What your boat looks like
Who else is on board
VHF channel monitored and hailing name
Helps authorities find you in worse case
Old 02-08-2014, 09:57 AM
I hear the wahoo are spotty now but thats it. How about May or so when the dolphin show??
Old 02-08-2014, 10:57 AM
Copper Collar Copper Collar is offline
In your float plan list what type of life raft you have.
Also some solar blankets (thin metallic looking ones that reflect your body heat in) and some water purification straws (I believe the are usually good for about 200 gallons, but for salt its only like 10-20).
