Old 03-01-2014, 01:39 PM
Srt44116 Srt44116 is offline
Default 23 seacraft. F300, F250, F200?
Hey guys looking for some info on the 23 seacraft master angler. Looking to buy a hull and reporter it. Wonder what people are getting for performance numbers with a F300-250-200. ( new inline4 200). Wonder what type of fuel mileage people are getting. Done some searching and seems like the f300 is right around 2.5-3mpg at 35. Can't find much info on the 250 or 200
Old 03-07-2014, 04:41 PM
bj bj is offline
I have a 2003 21' that I repowered with the new F200 4 cylinder last spring. I doubt it is enough for a 23', although it is surprisingly strong in the mid range and is slightly stronger than the the 200 Merc EFI it replaced. I get about 42-43 mph top end and my best cruise is around 25 mph @ 3.8 mpg. Overall in a day of running 20-30 miles offshore slow trolling for 4-6 hours I almost always end up averaging about 3.0 mpg. I feel is is very adequate for my 21' but would be very marginal for a 23'. Hope this helps.
Old 03-15-2014, 10:11 AM
23Seacraft79 23Seacraft79 is offline
Default 23 repower
I have been a die hard yamaha guy for years. Had twin 150's on a '88 26' mako and it was awesome. I just got a '79 23' and have been deciding what to put on her. My father is a yamaha certified mechanic and he even doesnt like the new plasma coated cylinders. Ive heard there are other problems as well, but to keep it short and sweet, u definately want a 225 or 250 evinrude etec with a 25" shaft. I am going to put mine on a armstrong or hermco bracket after fully enclosing the transom. This is just my opinion but have done alot of research and talked with people from both yamaha and evinrude and feel this is the way to go.
Old 03-15-2014, 12:32 PM
If you go with an E-TEC, check out this web site: http://www.etecownersgroup.com/. It's the CSC of the outboard world! Several very knowledgeable techs on there who can answer any question you may have in addition to those you haven't even thought of yet! Check out this post by a member who switched from F225's to 200 HO's: http://www.etecownersgroup.com/post/...9&postcount=13
Old 04-14-2014, 11:39 AM
shine shine is offline
Moderator
Had F225 and now have a F250 (2006) and its night and day, F250 gets me a cruise of 30 mph at 4000 and well over 3 miles per gallon. turning a 19 pitch 4 blade merc prop.
Old 04-18-2014, 11:45 AM
i goot an f250 ford iputz an beg engen. alls 4 wheal goes in wtater w seacraft. sunk 2..if yoou want 2 by forsall cheep inal
Old 04-18-2014, 11:58 AM
holly crap... spidycrab !!! hVENT seen him post in WHILE ... compare the weight to power and what speeds you will use the most... I am torn between the yami and the etec...
RUSTY PARKER
Old 04-20-2014, 11:38 PM
I love the f150 but i would stay away from the bigger 4strokes... And my dad isayamaha certified mechanic!! Definately etec...250 best engine on the market... I think u would be even better off with an optimax... Just my opinion.
Old 05-01-2014, 07:28 PM
Mike241 Mike241 is offline
yamaha's 3.3l four strokes are well proven esp the f250, will far outlast an etec....the new 4.2l are a great engine to havnt seen any problems with them either, tons of power and mid range, as far as the 300-250 in the 4.2 crusing fuel economy will b near identical the only difference between the 300 and 250 is a few ecm calibrations and how far the throttle plate opens. for the power id go with the 300 you wouldnt be disapointed!
-mike, master yamaha tech.
Old 03-24-2015, 07:30 PM
seakat seakat is offline
I would redo the transom to make it 30". I have a '99 w an F250. A friend repowered w an etec250 and gets much better performance out of it. I would suggest an etec 250. This guy rebuilds seacrafts and says that the 250 in etec is plenty of power. I would say the F250 is reliable and adequate, but I feel I could use more power.
