Old 03-03-2014, 05:26 PM
riptide riptide is offline
Default Brass scupper tubes question
Im in the process of replacing the brass scupper tubes on my 77 23 sceptre.The old ones were not to bad and the wood blocks are a little wet but no rot.
Has anyone gone from 1"tubes to 1 1/4" dia tubes? I have some 1 1/4od 316 stainless tubing laying around I was thinking of using.
I know alot of you guys sealed them up and went thru the transom but mine worked fine and see no reason to change them except to increase the size to drain faster.
Just wondering if anyone went 1 1/4" and how they work and if its worth it? Thanks
77 Sceptre 250 Suzuki
Old 03-03-2014, 10:21 PM
FLexpat FLexpat is offline
That is pretty much what I am planning for my 23. I have some 1-1/4" 316 stainless tube, 0.030" wall, that I'm going to use. I plan on annealing the edges with a torch so I can flare them easily and I am also thinking about passivating the stainless in nitric acid before I put them in - not yet sure if that is necessary or smart though... gotta do some more homework.
Old 03-04-2014, 08:03 AM
I would think the ss would work well if you could flare it. The brass flares ez with the right tool but the ss would not do well with that same tool. If you do something similar to what flex is saying it may work but hard as 316L is you may have a time getting the flare right.
Old 03-04-2014, 09:11 AM
bigeasy1 bigeasy1 is offline
I thought about going to larger brass tubes when I replaced the originals on my Tsunami,but I was a little scared off by having to enlarge the tube exit hole on the hull where its got that wedge to help suck out the water.
I ended up leaving it the way it was.
I was new to this kind of stuff when I did the resto,but looking back,I wish I had,because the 1" brass tubes are no where near large enough to drain the deck fast enough.
Not sure on flaring the stainless,but if you go with brass,it helps a lot to anneal the brass with a torch before you flare them.Heat the tube red and just let it cool.Flares a lot easier,with no cracks at the edge of the flare. They can split sometimes if you flare them raw.
All this,just for a boat ride
Old 03-04-2014, 10:10 AM
Are you guys using o-rings under the flared flange on the brass tubes?? I had replaced these on my Whaler years ago and bought the tube and a bag of o-rings.I'll mail o-rings if anybody needs them. I think it's intended to "cushion" more than seal.
Old 03-04-2014, 04:09 PM
Thanks OC - PM sent. The 1-1/4" tubes have 156% of the flow area of the 1" tubes. I got 0.030" wall thickness from McMaster Carr since it was as thin as I could get - I don't think I can flare the 0.045" stuff; 0.030" will be challenging enough anyways. I think Moeller does not make the 1-1/4" brass tubes long enough for the scuppers. McMaster has 1-1/4 brass tube but I'm not sure if it is a marine alloy so I decided to add some 316 stainless to a recent buy and try it - maybe several times before I get it right. I'm not rushed for time since I haven't even finished the transom yet, much less started the decks.
Old 03-04-2014, 05:58 PM
Flexpat you are right they do not make the 1 1/4 brass tubes long enough. 3 7/8" is the longest I can find them which is an odd size. You can get 1" up to 8" long. I made my own flaring tool and did a test flare on .049 ss tubing it worked but took alot of muscle on the wrenches.You have to remove any burr inside and outside before you flare or the tubing can split.
Old 03-04-2014, 08:28 PM
Seems like I bought 2' or so of the brass tube from McMaster years ago....anyway, I have the 1 1/4" ID O-Rings if anyone needs them let me know.
Old 03-04-2014, 09:12 PM
McMaster only sells 260 alloy brass or "yellow brass" in 1 1/4 tubing which is not marine grade and will eventually corrode in salt water.The ones Moeller sells are a special alloy.
Old 03-04-2014, 09:16 PM
Nice of you there.
