Old 04-24-2014, 08:47 AM
Default How did you get your fuel fill hose out?
Help!!!
Foamed in.
Cheers,
You know who
Old 04-24-2014, 08:51 AM
Some one told me it will come out if you blow in it!
Old 04-24-2014, 09:04 AM
FLexpat FLexpat is offline
I have never tried this on a fuel hose but it is an idea:
Get some flexible PVC spa pipe a little larger in ID than your fuel hose OD - 4' long or so. Glue a PVC slip-slip union on the end. Cut coarse teeth in the end of the union - you are making a long, flexible hole saw with plastic teeth but foam is usually pretty soft. Slide it over hose and cut as far as you can from either end by twisting the tube - you will probably need to put wire pulling lube inside the spa pipe. You will still end up with Popeye arms though.
This is how I have done fuel hoses that were not foamed (much):
Before you pull the old hose out use, use a barbed PVC union fitting to connect it to the new hose on the fill end. Use 3-4 pan head screws on each side of the union, screwed through the hose into the union to hold the hose on. This is smaller than hose clamps. Use a wire pull to put a heavy cord down the ID all the way through - this is your back-up. Push the new hose from the outside and pull the old hose from the inside.
You will need several drinks when you are done because your muscles will be screaming...
Old 04-24-2014, 10:18 AM
drtyTshrt drtyTshrt is offline
I drilled through about an inch from the end and attached a shackel to a come along and winched it out.
Redneck inginuity.
It worked is all can say.
Come to think about it I had to pull the new hose back in the same way.
Something about that turn from the floor into the side.
It was not a fun job.
The trouble with trouble is it starts out as fun. (Mark Twain)
1989 20ft C/C SeaCraft/Tracker 1989 200 Merc BlackMax.
Old 04-24-2014, 05:24 PM
hermco hermco is offline
Lube it then yank it dude.
Old 04-24-2014, 05:57 PM
It's truly a PITA. I wouldn't wish that on anyone.
Old 04-24-2014, 07:05 PM
Jokes are always welcome.
Drty and Flex thanks.
What about cutting a a pie hole in the gunwhale and blasting the foam w a pressure washer? I need more beer. Damn fill fitting wont lift for squat.
Keep em coming gang.
Cut the new hose w a cut off wheel?
Old 04-24-2014, 07:10 PM
Last spring it was the F`en TnT rebuild.
Cheers,
Potty Mouth
Old 04-24-2014, 07:30 PM
If you are gonna just yank it, then run a chain down the ID to an eyebolt stuck through a steel pipe cap that fits over the hose end on the inside. Mix in an A-frame and a chain hoist and hope nothing else gets ripped out with it. Something will give but it might pick the hull up a bit first so be careful. Tie a string to it before you pull it so you can get the new one in easier.
Old 04-24-2014, 08:02 PM
I have access to an elegant Yale forklift. She can lift 1600 lb rolls of cahhhpet, so I have the powah. Now I need to find a brain.
Is there such a thing as a flexible tip for a pressure washer? Since foam is the enemy, this is where I am focusing my thought.
