Old 05-13-2014, 09:59 PM
Default Engine height
So I know the anti ventilatin plate is supposed to be about one inch above the lowest portion of the stern. But does that mean when the anti ventilation plate is trimmed parallel to the bottom of the boat or trimmed all the way down? The below picture is trimmed all the way down (or very close to it). As it is now in the pic the leading edge of the ventilation plate is about where I think it should be after I raised the engine two holes. Should I trim the engine up so the anti ventilation plate is parallel to the keel to get the best idea of where I need to be height wise? Thanks guys
Old 05-14-2014, 04:43 AM
Depends where it is when running on plane but that has to be real close
Old 05-14-2014, 05:49 AM
For measurement purposes, yes.
Blue Heron Boat Works
Old 05-14-2014, 11:18 AM
Great thank you.
Old 05-15-2014, 04:06 PM
This is what it looks like while running and trimmed up. Still to low right?
Old 05-15-2014, 04:49 PM
Yep, need to be able to clearly see top of the AF plate above green water.
