Old 07-21-2014, 10:51 PM
regidog regidog is offline
Default Broken Mount Mount Lags
Broke 2 motor mount lag bolts below the surface. What's the best way to remove the broken lags? Thanks
Old 07-22-2014, 12:39 AM
FLexpat FLexpat is offline
It aint easy or fun - what I have done in the past is use some hard stainless tubing with an ID that is just a little smaller than the threads of the bolt (~ same size as shank), cut teeth in one end like a hole saw but reverse from normal (cut em CCW). Drill down over the broken stub - it will eventually catch the lag and back it out - you have to really press the drill in to make it catch. PM me if you need a bit of SS tubing - I have 1/4, 3/8, and 1/2 OD w .040 wall thickness. When you are done, the hole is bigger by a bunch and then you can have more fun...
