Old 08-13-2014, 11:12 AM
martin martin is offline
Default gemlux hi speed pick up
Hi I was wondering if anyone installed one of these and where on a 23 sf I/0 do I just put it in place of my other through hulls. Thanks Martin
Old 08-14-2014, 11:34 AM
I have one on the 21...if I remember correctly it should be about 18-24 from the transom...you can check by build thread and see it there.
Old 08-23-2014, 11:39 AM
Did you guys cut the hole out then rabbit the edges to flush it to the hull. Then glass the entire part into the hull..? How sis you guys install them?
Look at post #89 of my build...that should tell you more than you would ever need to know...
Old 08-24-2014, 12:04 PM
Calibogue Calibogue is offline
Mine is glassed in place...
Old 05-11-2015, 08:56 PM
Default Through hull
Nice and clean work guys
