Old 01-19-2015, 12:41 PM
bibijawa bibijawa is offline
Default wet foam in stringers
After grinding the inner sides of the stringers to prepare the area for the new fuel tank slats I'm going to glass in, I noticed water leaking out of a couple of areas where the woven roving was delaminating. My stringers apparently have wet foam. Since I'm not removing the deck I won't have access to the stringer tops. Will it be structurally safe to remove the sides of the stringers to remove the foam then glass those same skins back on?
