Old 01-20-2015, 10:39 AM
Brett Brett is offline
Default 27' SeaMaster, Wood Stringer
I'm replacing the transom on a recently purchased 27' (Sea Mistress/Bleu Bayou) and need some additional info about the stringers. She had been converted to outboard bracket but the inside of the transom was completely rotten. It has some good glass under the rotten wood so I thought it would be a fairly straightforward repair. The glass under the p
outboard bracket is also fine. However, I can get my finger inside one of the stringers from the rear and it is also rotten. Looks like wood to me but it is just mush.
So, a few questions. Would a 1967 SeaMaster have wood stringers? What happens if I leave the stringer as is? Am I compromising the strength? Or what is the recommended repair? The deck is preventing me from accessing very far up the stringers. Should a drill a couple exploratory holes farther up? The deck is still in pretty good shape so I would hate to also have to rip that up as well. Wasn't expecting the rotten transom and would love to get some use out her.
Thanks, Brett
Old 01-20-2015, 08:40 PM
Thanks, Brett
Sorry to hear that Brett. Where are you located? Not in your header.
I would find a good glass guy with thermal imaging experience. The tool is expensive but the actual knowledge to use it proficiently is priceless.
Old 01-21-2015, 09:37 AM
The strength is not in the wood stringer, but the glass that surrounds the wood. The wood was just used as the core...all the wood could be rotten, but as long as the fiberglass that surrounds the wood is not separating or flexible the stringer is good...If some flex, just glass over the old stringer and you should be good to go.
Old 01-21-2015, 09:07 PM
FAS FAS is offline
if its not a resoration,fix the dilemmas from the outside,patch what is needed for strength and safety,and enjoy the boat.
Old 01-21-2015, 09:26 PM
Water in a stringer will delaminate a stringer when it freezes. Or it can. So getting it dry or dry enough is a good goal.
