Old 03-03-2015, 11:12 AM
bluechip bluechip is offline
Default 1979 20' ma 140 suzuki
i am considering re-powering my 79 20' ma seacraft from a 1995 150 2 stroke omc to a 2005 4 stroke 140 suzuki
my kids like to water ski, tube, wake board and knee board with the boat. my question is What will be the difference in pulling power with the suzuki
thanks
Old 03-04-2015, 12:33 AM
As I posted on another thread last Saturday, a 4-stroke motor generally needs about 30-40% more displacement to produce the same torque as a 2-stroke. I believe your 150 has the same 2.7L/158 cu. in. block as my E-TEC. That says the 140 Zuke needs to be at least 158x1.3 = 205 cu. in. to have roughly the same torque that you're use to with the old V-6, but it actually has only a 125 cu. in. powerhead, so it only has about 60% of the displacement it needs for the same torque! I.E., there's no substitute for cubic inches! If you'll PM me with an email address I can send you the torque/hp vs rpm comparison curves for the 150 E-TEC vs the 163 cu. inch 150 Yamaha 4-S. Even correcting for higher gear reduction on the gray motor, the smaller displacement E-TEC still has 23% more PROP torque than the gray motor at 3000 rpm where you're trying to get on plane!
Now the 140 Zuke is a fine economical motor and my favorite 4-stroke because it's relatively light and the chain driven cams and extra gear reduction appeal to my basic mechanical engineering instincts. The extra gear reduction lets it spin a large slow-turning more efficient prop so the 30-40% extra displacement rule might be overstated for it. It's no doubt pretty strong for it's size. However that 150 is a very conservatively rated (and thirsty!) motor with a VERY strong mid-range, and if it's propped so you can turn it up to about 5500 with your normal load, I suspect that Zuke is gonna feel pretty weak in comparison, although you could probably reduce your fuel load by 50%! Now if the V-6 has a lot more power than needed for what you're using, the Zuke might be acceptable. To get 140 hp out of only 125 cu. inches, it's got to have pretty high lift and large duration "hot rod" cams that make power at high rpm and sacrifice low and mid-range torque, so don't know how much of that you can offset with gear reduction. Since you're looking at older motors, you might look at the early 115 or 150 E-TEC's (2007 was the first model year for both.) Wet weights of the 140 Zuke and 150 E-TEC are nearly identical, but the E-TEC will be stronger than your current V-6, quieter than the Zuke at 30 mph and it won't burn that much more gas than the Zuke because you won't have to use so much throttle to get the same speed.
Old 03-04-2015, 09:41 AM
bushwacker thanks for the reply, i understand completely what your saying, but the suzuki does has more than twice the compression numbers (85 psi omc 210 psi suzuki) which has to account for some power gain.
i no the old saying "there's no replacement for displacement" but the number two power adder is higher compression with that said i hoped somebody with a 20' ma w/140 suzuki would post some performance #'s
thanks in advance bluechip
Old 03-04-2015, 11:13 AM
210 psig is almost certainly a bogus number because that works out to be a compression ratio of 15.3:1, which is way too high, even if you're running 103 octane Av gas with aluminum heads!! I'd see if you can find what the specs are from a Zuke service manual. 85 psig does sound a bit low for the 150, so it may have some stuck rings and need a good decarb. And compression ratio primarily affects BSFC, but has sort of a 2nd order effect on power. And if you have to back off on spark advance to avoid detonation with the high compression ratio, you will lose more power from that than you will gain from high compression. I own an old muscle car and the race block I bought for it turned out to have about 12:1 compression ratio which is way too high for premium pump gas, so I tore it down and installed 9.5:1 pistons in it!
Old 03-04-2015, 04:46 PM
I agree, I have a Camaro with a small block Chevy in it with 14.8 to 1 compression and I have to run at least 112 octane. I usually run 113 oxygenated race fuel which is as good as 114. A stock mercury 200 has 125-130 lbs but we shave the heads down to 34 cc's to run 145-150 lbs but even then that is the absolute limit for 93 octane. Most go easy on the timing to run this much compression. The drag racers with 2.5 drag outboards are only 160ish from the factory and some of them guys cut them down to get over 200 lbs but they are running 112 octane at least!
*EDIT: I was wrong in my post earlier, I did some checking around and found this: "2005 Suzuki 140 hp - Specks: 185 psi to 242 psi with a 14 psi delta maximum between all cylinders" So I guess they are doing it some how with low octane fuel???
Old 03-04-2015, 05:16 PM
Well said fellas. I think Denny's original analysis is spot on.
Old 03-06-2015, 09:17 PM
I don't see that 210 as a bogus number. Others achieve it on other outboards and the quasi-adiabatic heating during compression could explain it on a tight 4 stroke.
Old 03-07-2015, 10:06 PM
I won't even try to comment on the technical side, or the comparison of the 150 2-stroke. But from experience with my kids and friends (12-13 years old), my 140 Suzuki on my 73 20SF pulls them just fine. Solas Amita 4 Blade 13.75X19 Prop.
However, no matter how much I try to squat the boat, the Seacraft hull is too efficient to make a big enough wave to satisfy my son and his buddies for wake surfing.
Lloyd
Old 03-08-2015, 08:14 AM
captain Lloyd,
thanks for your reply, what is your top speed and fuel consumption at cruise
thanks again mark
Old 03-08-2015, 10:41 AM
I do know this, I wouldn't mind having one on my 20' sf. They do have a good power to weight ratio. They say the 150's are more dependable with the bigger block but they are so much heavier. The 140 Suzuki is probably one of the best fits weight wise for a seacraft 20' hull if you must go four stroke.
