Old 03-06-2015, 07:07 PM
Default 23' C/C Anchor box hatch
I have been thinking about replacing my anchor box hatch in the bow of the boat. I was just going to replace it with starboard. Any pics of other ideas, latches, ect ? Picture is of existing hatch.
Old 03-06-2015, 09:11 PM
I think it would be difficult to remove/reinstall the bulkhead without taking off the cap. That would be a big project in itself.
Old 03-06-2015, 09:15 PM
Actually mine has been replaced with starboard and it was quite easy to do. After the rope is out and you take out the screws it will come out easy. You will then use to old one as a pattern for the new one. It does not have any structural value, just keeps the rope in place.
Old 03-06-2015, 09:37 PM
I made mine from 1/2" white Starboard and hid the wash-down hose there
Old 03-06-2015, 10:05 PM
FAS FAS is offline
actually, working on that part right now,starboard for sure,..
Old 03-07-2015, 09:41 AM
I don't like starboard as it tuff to glue, seal, match colors, screws bugger out easy and it loves to warp.
After cutting out the old bulkhead, save it for a pattern. The new one will have to be installed in two pieces.
I chose to use 3/4" PVC board as it is simple to seal, glue, cut, sand & paint.
1. Cut your new bulkhead using your old piece as a pattern.
2. Cut out the hatch door with a jig saw.
3. Now cut the bulkhead in half vertically down the center.
4. Trial fit the hinges, hardware, speakers what ever.
5. Install the two pieces from the inside using PVC glue too seal the two pieces together at the cut lines.
6. Sand & Paint, install the hatch & hardware, then caulk the sides.
7. Load it up with Sears Catalogs
Old 03-08-2015, 12:44 AM
Alienor Alienor is offline
Looks like mine let me know replacement
Old 03-08-2015, 09:57 AM
Thanks guys, some great ideas and input.
