Old 03-26-2015, 04:59 PM
bbh57 bbh57 is offline
Default 30 inch motor
So I came across a great deal on a Mercury 225 for my boat but its a 30'' shaft. So what are my options? And pros and cons? Raise the bracket? Weld a plate to the bracket to allow higher mounting?
Find another lower unit? nice motor hate to walk away from it, priced right as well.
I'm all ears guy's...
Old 03-26-2015, 05:32 PM
Hey Bill, get a manually adjustable jack plate. Mount it and raise as high as you can or need and then bolt it up tight. You might be able to make up the 5". See Ken's setup (Kmoose). Or do it the hard way, rebuild the transom...yuck.
Old 03-26-2015, 06:09 PM
I just pretty much just gave away a CMC electric jack plate with my Steiger I just sold three weeks ago.
Old 03-26-2015, 07:11 PM
Do you have an full transom with a bracket or open? Putting a bracket on a bracket may be I little too much.
Old 03-26-2015, 07:16 PM
Moose, I have a bracket with a closed transom.
Old 03-26-2015, 07:17 PM
What about welding a plate to the bracket? Guess I could bolt a plate on too.
Old 03-26-2015, 07:18 PM
This is my setup with a 30 inch motor before I adjusted the height up to where I have it now. The CMC bracket works great and as a diver I really like the ease of entry into the boat.
Old 03-26-2015, 07:25 PM
That could work but I think there is a bolt on solution. Let me do some research and get back to you.
Old 03-26-2015, 07:31 PM
Here you go!
http://www.cmcmarineproducts.com/pro...ical-extension
Old 03-26-2015, 07:41 PM
Looks like the deal... Thanks Moose
