I am considering doing something similar to what Frizzle did with his 1974 Sceptre with my 20sf that is currently i/o. I am kicking around the idea of converting it to outboard, but would like to do it without having to use a bracket. Do you think that bracing the transom by adding a few knees connecting the transom to the hull would be sufficient to support an outboard? I know that the SF hull was also made for an outboard, so I thought that I could just maybe modify the transom of my i/o to resemble the transom that they made for outboards so that it could structurally support an outboard. Advice and thoughts?? Is this doable without a bracket? Is it advisable without a bracket, or will it cause stress to my hull?
![]() Quote:
Current SeaCraft projects: 68 27' SeaCraft Race boat 71 20' SeaCraft CC sf 73 23' SeaCraft CC sf 74 20' SeaCraft Sceptre 74 20' SeaCraft CC sf |
It will most likely work without much modification to the transom. How thick is the transom core?
http://www.boatbuildercentral.com/ ![]() my rebuild thread: http://www.classicseacraft.com/commu...ad.php?t=22090 |
Frizzle- I was planning on replacing the transom if necessary and potentially notching it down a few inches.
Shine- the transom is about 1-7/8 inches thick, I don't know much about how fiberglass is laid, but I'm guessing the core is about 1-1/2 inches thick or so. |
Is this a project a fiberglass novice could/should undertake? I have a friend that does fiberglass work that I know would be willing to offer advice/guidance, so I wouldn't be flying totally blind.
![]() Quote:
Two 3/4" marine plys or either marine foam like coosa will be plenty strong with a good layer of glass on each side.
Thanks frizzle. I would say i at least have basic skills i'm fairly handy mechanically. I think this is something i am capable of.
Frizzle, you're in the pamlico sound area right? If so, i would love to check out your seacraft collection sometime and pick your brain a litle about fiberglass I'm in little Washington. |
