Old 05-10-2015, 08:14 AM
cdlong cdlong is offline
Default Remove stains from gelcoat
I have 5 stains that I have tried the 2 cleaners on, with scrub pad & stiff brush. One stain lifted well, the other 5 are a PIMA! Anyone know how I can remove them before I apply the floor sealer to get her shine back?
Old 05-10-2015, 10:22 AM
FSR by Davis will work well on stains like that. It's basically oxalic acid in gel form. Brush it on, leave it for a few minutes, remove with water and a sponge or brush.
Rod
Old 05-10-2015, 02:31 PM
Some stains can get so deep in the gelcoat that you have to sand them out, and sometimes that may not even work..
Old 05-10-2015, 04:06 PM
erebus erebus is offline
Mary Kate On-and-Off.
Its our go to waterline stain remover here at the yard come haulout time.
Just dont let it drip on your galvanized trailer!
(FYI- its a combo of hydrochloric, oxalic and phosphoric acids)
Zachary
Old 05-27-2015, 10:55 PM
CJg8r CJg8r is offline
I've had good luck with snobowl toilet cleaner
Old 05-28-2015, 12:20 AM
BigLew BigLew is offline
If you believe it is an iron based stain (rust stain), go with Iron-Out. Get it in your grocery store or Home Depot.
Also, You might try white vinegar first, rinsed and then go at it with baking soda.
Just a thought- no garruantees
Plan accordingly!
Old 05-29-2015, 05:41 AM
Thank you!
Old 05-29-2015, 02:12 PM
Originally Posted by erebus View Post
mary kate on-and-off.
(fyi- its a combo of hydrochloric, oxalic and phosphoric acids)
wear a mask and have plenty of ventilation!
Old 05-29-2015, 06:20 PM
Plus heavy gloves and eye protection!!
Zachary
Old 05-29-2015, 06:38 PM
WaveWalker WaveWalker is offline
Muriatic acid, spray on and rinse immediately. Do this as many times as necessary unitl stain is gone, will also remove barnacle and shells off bare bottoms. I recommend stripping any wax off the gelcoat with degreaser first so the acid will work better then re wax when done. Can be used on motor for barnacles but do it at own risk! ON then OFF immediately! Will turn bottom paint green if allowed to run on it. Used this when I worked for a popular boat detailing company in the keys. THIS is done at your own risk. Cjg8r not to rain on your parade but keep snobowl off your boat, it is an abrasive and will scratch the crap out of your paint and gelcoat.
