Old 02-05-2016, 07:56 PM
Scott1115 Scott1115 is offline
Default T-top canvas replacement
I plan to remove and replace the old torn and leaky canvas with new. Where the antennae and radar wires go through the canvas I will need to make holes. What should I use to make the holes and is there anything special I should do to prevent the new canvas from tearing in these areas after the holes are made? Plan on using Sunbrella (or similar) material.
Thanks,
Scott
Old 02-06-2016, 07:45 AM
when you make the holes have someone sew around them.
Old 02-06-2016, 09:36 AM
Thank you. Looks like the current one was either cut or edges singed with a soldering iron.
Old 02-06-2016, 10:21 AM
I would go with a Weblon canvas vs. Sunbrella.
Old 02-06-2016, 10:34 AM
Snafu - what is the benefits of Weblon vs Sunbrella?
Old 02-06-2016, 07:54 PM
The Sunbrella is canvass and when a bird shits on it and you scrub it off, you eventually lose the waterproofing and get a leak. Weblon is more like a plastic that is easy to clean and looks the same. Same warranty. Google it, you see the difference.
Old 02-07-2016, 10:47 PM
Thank you
