Old 03-25-2016, 09:31 AM
capttodd capttodd is offline
Default What trim tabs to use?
I have restored a 1974 23 . I have a Hermco twin bracket with a single 30" shaft Yamaha 250, we are having a hard time finding trim tabs that will fit.
The bracket is mounted as per instruction from Hermco. Could someone that has used this bracket give my the correct trim tabs to use.
Old 03-25-2016, 09:52 AM
Are your accuators too long? if so you have 2 options . . . trim holes in the swim platform or use the bennett short actuators
Old 03-25-2016, 09:55 AM
Default trim tabs
too long
Old 03-25-2016, 10:32 AM
Copper Collar Copper Collar is offline
Have you called Hermco to ask for a P/N # for a new actuator? He told me about this when I was ordering my bracket, so I would think that he would have an idea of which ones will work.
Old 03-25-2016, 10:51 AM
I think you want the M120 actuator. Capt. Terry had similar questions so I just measured the length of my standard actuator yesterday for comparison. The 11.25" dimension on the short actuator measures 13.5" on the standard actuator. Don just notched my bracket for the standard actuator, but he should know if the short actuator will fit under swim platform.
Old 03-25-2016, 11:00 AM
Thanks. I got in contact with Don and he recommended the Lenco Edge series
I have the same boat/bracket, etc. Bennett provided me with shorter rams and I notched the flange a little. I can get a pic later if you need it.
Found it
Old 03-25-2016, 11:26 AM
If I were doing this again, I would mount them a little further inboard.
Old 03-25-2016, 12:58 PM
Not to change the subject but I see Bennett is offering electric actuators now with a lifetime warranty. I have used Lenco for years and like them but they only have a 2 year warranty. This is a step in the right direction for Bennett in my eyes and will likely put Lenco on the street if they don't follow suite with a similar product backing.
Old 03-26-2016, 08:22 AM
Yeah Ken, I found the Lenco product backing is being told to buy a new actuator at a smooth $150+. The Bennett's in my SeaCraft work all the time and are as old as the boat!!
