Old 04-22-2016, 08:28 PM
seecraft75 seecraft75 is offline
Default 75 18
Just put Susuki Df175 on my 18 potter built. What size prop should I use
Old 04-22-2016, 09:48 PM
Default Gear
I'm thinkin' a 13-3/4" X 27" S.S. 3 B Power Tec and a 12.5' diameter Kevlar Drag Chute!
Old 04-23-2016, 10:34 PM
Yikes! Max out the prop. Keep us posted on #'s. Hull was rated for an old school (light weight) 150hp two stroke.
Old 04-24-2016, 06:13 AM
You won't be able to realize how good the hull is when the only thing in the water is the prop. Good luck and enjoy
Old 04-25-2016, 03:55 PM
Better move EVERYTHING forward, (unless it weighs the same as the 140)! I have a DF140 and it's too heavy, but manageable.
Old 04-29-2016, 08:22 AM
my Yamaha 2 stroke 150 did ok for 16 years. The 175 weighs 60 lbs heavier. I know its a stretch, just have to be on guard and use common since.
Old 06-11-2016, 04:44 AM
seaojoe seaojoe is offline
i'm on my 2nd 18, the first had a 200, later replaced it with a yamaha 130, present boat has a merc 125.
the 200 was a beast. boat would chine walk and make for 'wet feet fishing'. always had plugs in and had to be extra vigilante at dock. the yammy was perfect at dock, as is the merc 125.
as others have said, these boats do not need the extra hp. be careful out there
Old 08-03-2016, 03:09 PM
Default performance
Put the 175 Suzuki on my 18. For right now running a 15x22 4 blade. cruise 4500rpm speed 39
WOT trimmed up 51
nice is it stays on plane at 2900rpm
Old 08-16-2016, 12:16 AM
sidelock sidelock is offline
Are your scuppers under water with the weight of the 175 Suzuki or did you raise the deck ? I was playing with the idea of putting a 115 Etech on my 18' till I found out what they weigh. I'm running a 1998 C115 Yamaha at 330lbs and I wouldn't feel too comfortable hanging anything much heavier on there.
Old 08-25-2016, 11:32 AM
The bilge access in the 18 is terrible. With a heavy motor you can forget about getting to the bilge in any kind of chop. You'll also need a permanent watertight splashgate to keep water out of the floor baitwell.
