Old 05-12-2016, 12:42 PM
coltblue69 coltblue69 is offline
Default Is Yamaha 115 4 stroke enough power for a 73 Seafari ?
Guys, I need some opinions.
I currently have a 1986 150 Yamaha that just bit the dust and need to re-power. Have a great deal on a 2016 Yam 115 4 stroke but need to know if that will be enough power. I keep it mostly to bay fishing and occasionally in the ocean ,but mostly inshore. Most of the time its just me and a friend. Any advice? Thanks to all.
Old 05-12-2016, 02:21 PM
Forgot to mention that it is a 73 20 ft Seafari
Old 05-12-2016, 03:28 PM
If you get either Gillie or Ken Reeves (PropGods) to dial your wheel in I believe you would see something like -
Minimum planing speed - 15 Mph
Cruise Speed - 20-24 Mph
WOT - 33-35 Mph
You'll probably be well north of 3 mpg.
If that would be suitable for your use, you will be happy with that motor. Have it serviced regularly and it will treat you right.
Old 05-12-2016, 07:01 PM
Default Thank You Terry
Thanks Terry for the info. 30 to 35 is as fast as I need. The 86 150 topped out at 44 mph and I rarely ever went WOT.
Old 05-12-2016, 07:20 PM
I am just one "Data Point" and I'm sure others will respond shortly. There are a few here like me that run 90's on the 20 footers and I think "Tiny" has a 90 on a SeaFari. The nice thing about the 90's or 115's is you don't blow the beer out of your cup on the way home! You can sit back, motor along, steer with your feet and tell extremely "tall" fishing tales.
Old 05-12-2016, 07:58 PM
Balance and min plane speed are some of our favorite friends.
Old 05-12-2016, 10:22 PM
Engine weight is more important than power on the 20' hull. Back in the 60's and 70's many were sold new with 85 hp motors (rated at the powerhead instead of prop!) Most folks have no idea how efficient the SeaCraft hull is! Modern hulls need lots of beam at the transom to handle the weight of a 4-stroke motor, so they have more drag, require more power and don't ride nearly as well as the relatively light and slender SeaCraft! That's why most folks today think any 20' boat with less than 200 hp on it is underpowered! The 19/20' hull was designed in the mid-60's for the biggest motors then available, the I-6 Merc and V-4 OMC's, which weighed 300 lbs or less. Ran my Seafari for 31 years with a 115 hp (~100 hp at prop) V-4 on the transom. With a light motor and trim tabs, you can ride very comfortably SITTING DOWN in 2' square waves at ~12-14 mph. With a heavy motor on the transom, it's harder to plane that slow and the boat won't run as flat so it won't ride nearly as well. That said, at least the Seafari has more weight forward than the CC models, so it tolerates a heavier motor a little better, plus the extra hull stiffness provided by the bulkhead, cabin top and coamings will make it feel more solid.
Old 05-12-2016, 10:35 PM
Thank you Bushwacker.Good info . I had my Seafari since 1978 and love the ride! It will outlast me!
Old 05-13-2016, 10:40 PM
Tiny Tiny is offline
I've got Father Franks old boat. It's still got a 90hp optimax, which is great. It runs well. It's very economical. Happy with it for sure. PS optimax is heavy, we keep the plugs in, but that doesn't bother us. The boat is all original.
Old 05-14-2016, 12:04 AM
Skipper T and Bowrider have a 19 with a 115 ETEC.
The balance is perfect.
The ride is envious.
Not a hot rod.
Just right.
