Old 05-17-2016, 06:03 PM
Default 77 Seafari deck plugs
I'm sitting here watching my boat collect rain. I know that this is not a Boston Whaler, but is it possible she could self bail at rest? Believe deck is sealed from bilge. I can see a new bilge pump and float switch but I'm not positive it's wired to a source to power the pump, should the float activate, with battery switch off.
Will power ignition and switch bilge to manual when this subsides. Just wondering when to pull the deck plugs.
TIA
Part II
Old 05-17-2016, 07:18 PM
Potter raised the deck an inch or two in about 74 when he changed from the 4 stringer to 2 stringer hull, so I think you'd be ok, but easy enough to just pull the plugs and check. Double check to make sure PO did not install drain holes in the step down.
My bilge pump is wired direct to my dual purpose battery with an in-line fuse so it will run even with Battery switch off.
