Old 05-27-2016, 07:33 AM
jwclbi jwclbi is offline
Default 20 CC WOT numbers
Hello, I have 1973 20CC with a 1998 225 EFI Merc. Put the boat in yesterday after installing a new garmin gps. The problem is, with 4 adults and 40 gallons of fuel i was only getting 48-49 miles an hour. The question i have is anyone running same boat with similar power and what numbers are you getting and full throttle? compression test today. thanks
Old 05-27-2016, 08:20 AM
"i was only getting 48-49 miles an hour"
Only??? With four people?
Old 05-27-2016, 04:23 PM
yeah i know that sounds bad but but 10-12 years ago she ran upper 60's with me and one guy on board with a handheld gps. I never had gps on the boat until I installed one this spring. Compression test today showed why, all 6 cylinders were low 90's.
Old 06-03-2016, 10:51 PM
Reelsknotty Reelsknotty is offline
I had an '86 20' with a 225 Optimax and it was a 54mph boat. I saw 56 a few times, but never more. Based on that, id say you're in line.
Old 06-04-2016, 07:43 AM
pelican pelican is offline
confused...
all cylinder reading the same number ?
Old 06-04-2016, 09:58 AM
Check the cavitation plate make sure it's 1.5" above the bottom v. For what it's worth, I just put on a Merc 225 3.0L carb motor on my 23 WOT bounced b/w 49.3mph and 48.6.
