So I am trying to get my trailer ready for the Seacraft meet at Crystal River, and my leaf springs are in bad shape. So the question is, its a double axle trailer with leaf springs that are connected in the middle and I measured from bolt to bolt and they are like right at 21.5 from the middle of the bolt to the middle of the bolt.
So now I am trying to find the springs locally to replace them myself to save money, and I found these I figure with two sets of them that would be a maximum of 4,ooo lbs, which should be fine with a 20' Seacraft and a 115 motor I would think. Looking for advice, thanks. Tom http://www.tractorsupply.com/tsc/pro...y?cm_vc=-10005 |
Don't forget fuel and gear weight, as well as the weight of the trailer itself. Close maybe?
Actually,the weight of the axles, wheels and tires wouldn't count(on ground)so I suppose so. |
http://www.tiedown.com/
check out these guys ... also hit ebay and amazon... you might be surprised at the prices ...just keep an eye on shipping cost ==== edit on tiedown.... they are wholesale only it appears now... hit the other 2...
80 23 SCEPTRE TWIN 135 MERC OPTIS 75 20 Master Angler 115 Mariner Tower of Power RUSTY PARKER http://i92.photobucket.com/albums/l2...eyemailtag.jpg |
I noticed on that site, that the springs were rated as individual ratings. On some other sites, the springs were rated for the axle rating (combined).
Don's suggestion is who I use. Great prices.
Snookerd |
I use a local guy...and he has told me that if you are dipping in saltwater, no amount of rinsing will get you more than a few years on the springs. I use my trailer 2x a year and after 5 years new springs.
[SIGPIC][/SIGPIC] "If You Done It...It Ain't Braggin" my rebuild thread: http://www.classicseacraft.com/commu...ad.php?t=18594 |
Terry speaks the truth. It's not difficult to change springs and associated hardware...with the boat off the trailer..., a few 4 1/2" cut off wheels, large hammer, some money, impact wrench and off you go! I think I've done it about 8 to 10 times on various trailers.
I upgraded my springs the last time from 1750# to 2000#, made a big difference in the trailer's stability. I think it was a $5 difference per spring. Oh yeah, remember to specify the 9/16" bolts! I've seen people use 1/2" bolts with a nylon spacer, no good in my opinion. |
I rechecked my measurements and they are currently 21.5 inches but I assume as they have gotten wore out they have expanded out, so I am guessing that I still need the 20' ones. Thanks for the reminder on the bolt size. I am going to see if I can find some that will work locally, if not I will try Amazon/ebay as you guys suggested.
Thanks Tom |
Tom, here's another outfit I've used that has a good selection of parts.
One thing you might consider that might add a bit of life to the springs is spraying them with some LPS3 to penetrate between the leaves and then spray them with automotive undercoating before you install them. I did that to my 1985 EZ Loader roller trailer and I'm still running the original springs! I have inadvertantly dunked the springs a couple of times, although I don't normally have to dunk it. I've also repeated the LPS3 spray a couple of times. BTW I emailed you a list I came up with of the weights of typical boat gear that might give you some idea of total boat weight. Denny
