Old 09-16-2016, 09:27 PM
Step Up Step Up is offline
Default Will the Alpha 1 Gen 1 outdrive pair with a V8
I was thinking about converting to an out board but I have decided to stay original. The boat has a 6 cyl. I need t now If the outdrive will support the V8. I am not sure what gears are in the outdrive as it is set up now.
Old 09-16-2016, 09:38 PM
FLexpat FLexpat is offline
Get a 1.5 ratio and fine to 300 HP
Old 09-17-2016, 10:06 AM
bigeasy1 bigeasy1 is offline
Just as mentioned above, it will handle the most V8 engines up to 300 hp without any issues.I run an older Alpha drive with a 350 ci 260hp engine and it does the job nicely.
Like FLexpat said change to a 1.5 and have fun.I have a 1.62 gears in mine so I had to fiddle around with a few props to get the right one but it works great.
All this,just for a boat ride
Old 09-17-2016, 11:45 AM
Awesome but how do I now what gear is in the existing out drive. It has the 165 hp 6 cyl. I found a chart on line and it has it has a 1.62
Old 09-17-2016, 12:01 PM
A couple of options for checking. Run the serial number online. Count the rotations of input and output shafts if it is off the boat or open the cap and count gear teeth. 1.62 is fine you will just need more prop pitch.
Old 09-17-2016, 08:32 PM
Nice Ty
Old 09-26-2016, 08:23 PM
pelican pelican is offline
those older alpha drives,they had low volume,high pressure water pumps...
follow me on this one :
the newer vortec motors,these require a larger volume of water,to cool it properly
that drive,will not provide the correct,required water flow
2 choices :
punch a hole in the bottom of the hull and install a highspeed pick up - using a bravo style water pump
upgrade transom assembly and outdrive to the newer alpha I gen II drive and transom assembly
yes,gear ratios are different from that old 165,to a v8 drive...
