Old 10-29-2016, 06:12 PM
Default Single or dual axle trailer for a 20
What's the consensus? Have an opportunity to get a great deal on an '07 Venture single axle, non torsion with brakes. The Master Angler and the Seafari both sitting on duals, and always liked my brothers 18 sitting on a single. What do you think? TIA.
Vezo.
Yes, it has a mounted spare.
Old 10-29-2016, 06:58 PM
Jeeeez Michael you only have to go like 53' to your ramp, how much trailer do you need!!!
Old 10-29-2016, 08:05 PM
What size tires does it have on it and how much load are they rated for at max pressure? If it has 6 lug wheels like mine, it has a 5000# axle, so trailer capacity would probably be about 4000# which is plenty for either boat.
Old 10-29-2016, 08:34 PM
TomParis TomParis is offline
It's a nice trailer, had a pathfinder on it before and to answer your question it has 15 inch tires.
Old 10-30-2016, 01:43 AM
10 ply radials.
Old 10-30-2016, 10:50 AM
72potter20 72potter20 is offline
I tow mine all over from tampa to Englewood with a single torsion axle
Old 10-30-2016, 11:09 AM
caper caper is offline
Single axle - better all around for 20.
Old 10-30-2016, 01:43 PM
10 ply radials.
Those may be load range E tires, which should be overkill for a 20' SeaCraft.
The load capacity info you want is molded right into the sidewall. On my tires it says:
"LOAD RANGE E, MAX LOAD SINGLE 2830 LBS @ 80 PSI MAX PRESSURE" These are ST 225/75R15 steel belted radials I bought this July; doesn't say how many plies it has.
My spare, 1 of 2 tires previously on trailer and similar to what it came with new, is a bias ply: (Tread: 5 ply nylon, sidewall: 4 ply nylon; 8 ply rating) Label says:
"LOAD RANGE D, MAX LOAD 2540 LBS @ MAX INFLATION PRESSURE 65 PSI"
Original tire load capacity of 5080 lbs is pretty close to axle rating of 5000 lbs (5000 lb axles typically come with 6 lug wheels which mine has); the galvanized steel EZ Loader roller style trailer weighs about 900 lbs, and trailer is rated for a 4000 lb boat.
Based on my tow over to Homosassa from NPB and back for the Scallop gathering, my gas mileage was about 5% better than normal, so I believe the steel belted radials do indeed have a bit less rolling resistance.
Old 10-30-2016, 04:06 PM
I agree with this . . . Single Torsion Axel Roller would be my preference.
Old 10-30-2016, 04:35 PM
Real funny Don. Honestly, I plan to be all over Florida, bugging anyone who is willing to teach me some new fishing techniques, diving, lobstering, spearfishing, and ultimately do my first Bahamas crossing.
READ: Starting with anyone who may or may not have enjoyed my hospitality last month!!! Haha
Vezo.
