Old 02-09-2017, 05:06 PM
GrumpyDuck GrumpyDuck is offline
Default New Member - New Project
Hey everyone! I picked up a 1978 23' SeaCraft a few weeks ago that's in need of some work. The hull is in great shape and the stringers look good but the deck and gunwale need some work, not to mention fittings and so forth topside.
Seems like most folks here have really nice looking boats or are working towards that. As much as I like gelcoat and bright white this thing is primarily used for guided duck hunts on open water so flat gray, tan and green is about as fancy as it will get.
I had to get her set up in a hurry about half-way through this past season and took a few shortcuts I'm not happy with - the "console" being a prime example. The previous owners made some curious decisions as far as the deck goes too. Taking serious water over the transom or bow would have been an issue since it would go directly to the bilge. The aft "hatch" has a gap between it and the deck of about two inches, and the forward carpeted decking just lifts up to reveal the bilge.
For now the big ticket items are to fix up the gunwale, strip down the deck, put hatches in, fabricate a center console and figure out whether the internal tank is any good. I've had to run top-side tanks due to fuel contamination I didn't have time to address.
So far all I've had time to do is get my decoys unloaded and start draining the internal tank.
I've been in sponge mode since I found this forum and a few others. Lots of good knowledge to absorb. I intend to put the info on props and glasswork to good use in the near future.
I live in central NC but mostly use the boat on the Pamlico Sound west of Hatteras.
Old 02-09-2017, 07:49 PM
Wow- that is a special purpose craft, for sure! Makes me wish I was closer to NC to take advantage of some fine duck hunting. Good Luck with the project.
Old 02-09-2017, 09:42 PM
FLexpat FLexpat is offline
Wow - never considered a 23 for ducks/geese. Interesting - I like it for bigger water - how does the dog get in? Looks like the PO implemented side drains like the 25; you might want to look at other options if the deck has not been raised. Looks like it is not so heavily (re?)built that it is way out of balance so it could be easy- if you want a console maybe think about a very small skiff style one. Tabs might help for the clients to stay a bit drier on quartering seas.
Old 02-09-2017, 10:58 PM
My dog has been using the swim platform to get in and out while she's working - though getting in takes me grabbing her vest to get her all the way in when she comes back with a duck.
Balance seems pretty good on her own but she does like to lean if weight isn't distributed evenly. I've been shifting customers around as needed on the run to and from wherever we've been hunting at. They all sit forward anyway, so the only one who gets wet is me. It takes pretty rough water for that to happen so I'm not sure if tabs are something I want to get into yet.
The side drains seem a little sketchy to me and I can't tell if the deck has been raised or not, but I don't *think* it has.
As far as the console goes smaller is better since it needs to be out of the way. I haven't been able to find anything that suits my needs so that's the first thing I'll assemble and glass on my own. Initially I was considering plain plywood or perhaps coosa but now I'm leaning towards pre-coated composite of some sort to save on labor and time. Just need enough space for steering, throttle, simple gauges and a GPS.
Old 02-09-2017, 11:04 PM
BA17 BA17 is offline
That rig needs a console with a long seat/bench/decoy box off the front of the console and a scissor rig. Throw some paint on it and roll on!
Old 02-10-2017, 08:03 AM
mr gumpy
u pickups dat ole seacraft from me cuzin. he full of duck sheet don't lik what he did to dat sheer line. piss me off.
id use da duct tape sit under the helm fer cover up da hatch gap. it last more seesons.
see ya sam
Old 02-27-2017, 10:55 PM
Started into teardown today. Transom needs fixing too, one of the bolts on the motor bracket pulled through when re-mounting it a few days ago.
Old 02-28-2017, 04:49 PM
always wanted to turn a 20' into a duck boat.....this is better!
1974 23SF
Old 02-28-2017, 10:18 PM
Further destruction and teardown today. Nothing under the deck is glassed, just lots of raw wood and machine screws. What is it with machine screws?
Good news is the tank looks OK from the surface but I won't know for sure until it's emptied and pulled.
Old 03-01-2017, 08:14 AM
Obviously not the original deck. doh!
1974 23SF
