Old 02-18-2017, 11:59 AM
zendora zendora is offline
Default Reduced to $30K - 1978 23’ SeaCraft Restored Savage Inboard CC Doghouse w Cuddy
PayPal transaction ID 0E737385KU5805232
New Price 8/22/18 - $30k
Current hours 650
Located South Shore, MA
Refit to Custom Standards 2010-2015 (see pics and details below)
2000 PCM Fuel Injected 5.7L V8 310HP (Factory leftover installed new in 2010)
Hours: 550 (approx)
ZF velvet drive transmission
Straight inboard with PSS dripless shaft seal, 1 ¾” stainless shaft and 16” bronze propeller
Fuel: 110 Gallons (2 x 55 gallon aluminum tanks with selector valve)
Cruise 22-24 kts Max 32 kts
Complete interior paint, new bootstripe, new Taco white vinyl rub rail. Interior was done with Interlux Perfection and Kiwigrip non-skid in a custom faux-plank pattern
Deck plates and cap rails re-cored
One of 15 Savage models built with straight inboard configuration, all built between 1976 and 1978 according to the production records on this site. This hull is one of five launched in 1978, the final year of production for the Savage inboard.
Nearly everything on the boat has been replaced new since I purchased it in 2010. Below are some highlights and I’ve done many more miscellaneous upgrades not listed. Everything has been done with function, form and durability in mind. This is an excellent 23’ boat that has handled everything the sea has thrown at her since I’ve owned her. She has served me well and I hope her new owner enjoys her as much as I have.
Thanks for looking. Please call me with any questions at 857.526.2659 - Mike
Electronics/Nav Equipment:
Garmin NMEA 2000 Network backbone
Garmin GPSMAP 5208
Garmin GMR 18 xHD broadband radar
Garmin GSD24 broadband sounder module
Garmin STRIKER 7sv CHIRP Downview and Sideview
Airmar B164 tilted element 1kw thru hull transducer
Raymarine EVO 100 Autopilot
Fusion stereo with Bluetooth & USB port
Icom VHF radio
Blue Seas waterproof switches
Dash mounted compass
Electrical system:
Complete overhaul 2015 by Crocker’s Boat Yard, Manchester MA. Every component of electrical system removed and replaced new - all wires, including main battery runs, battery isolator switch, heat shrink butt & terminal connectors, terminal & fuse blocks. All terminal blocks clearly labeled and wire runs organized to meticulous custom standards. 2 New Die Hard Platinum AGM 12v batteries. New high output internally regulated alternator.
Doghouse/Helm:
Custom fiberglass leaning post with storage drawers, vinyl upholstered cushions, backrest by Birdsall Marine with 3 cup holders and 4 rod holders. Storage space under leaning post (currently houses livewell).
Custom powder coated aluminum “dog house” style console, reinforced aluminum sub frame mounted to deck and secured to stringers, forward tilting heavy duty hinge, Starboard plates on all contact points (no metal on metal) and heavy duty locking latches. Custom designed for durability, functionality and timeless profile fitting overall look of the boat. Wire runs throughout with removable Starboard headliner. Reinforced mounting plates for radar, antennas and outrigger bases. 4 welded rod holders. Fore and aft 1000 watt spreader lights on separate switches. Safety glass windows with waterproof rubber seals. Clutter free dash layout, excellent visibility and protection from the elements. Overbuilt construction and looks mean as all hell.
Fishing Equipment:
Taco Grand Slam outrigger mounts
Bly 20’ retractable carbon fiber outriggers, double rigged with Rupp Knockout release clips
4 T-top mounted rod holders
6 gunwale mounted rod holders, including 4 LD Marine 0 degree swivels
Insulated in deck fish box with macerator
Rule 500 GPM livewell pump and 35 gallon livewell tank under leaning post
1978 23' Savage I/B
ZEN http://s1080.beta.photobucket.com/user/mfeenan/library/
Old 02-18-2017, 12:37 PM
Very impressive and Bad Ass!!! Best of Luck.
Vezo, Part II
Old 03-25-2018, 12:35 AM
John3325 John3325 is offline
Bump for a bad ass boat.
Old 05-08-2018, 02:19 PM
Thanks John. Boat is going in within the next week or so.
1978 23' Savage I/B
Old 02-18-2017, 01:38 PM
ccmontauk ccmontauk is offline
One of my favorite boats on the site. GLWS!
Old 02-18-2017, 09:48 PM
bobr338 bobr338 is offline
Good luck with sale! That doghouse has perfect lines, nicest I have seen by far.
Scituate Mass
1976 SeaCraft SF23
Old 02-18-2017, 11:16 PM
What a battle wagon!! Nice!
GLWS
Old 02-19-2017, 11:47 PM
Wow, I wish I had the $$$$ for this one. Absolutely beautiful.
Makes me want to hold onto my Sceptre for the long run and do a conversion later on down the line with brackets outboards on the back.....
Old 02-20-2017, 12:50 AM
Thank you all for the nice comments. I hate to part with her but I'm ready for something a bit bigger. She'll make someone very happy.
1978 23' Savage I/B
Old 02-21-2017, 11:54 AM
Zendora,
Where in weymouth did you keep it? I'm up the Quincy River at Town River Marina. Surprised I never saw it on the water, I sure would have remembered seeing that SC on the water.
