Old 03-04-2017, 02:19 PM
sisu22 sisu22 is offline
Default inside of engine box question
Do i put foam back in or something else .What did others do
Old 03-04-2017, 09:52 PM
Surfnski Surfnski is offline
I removed what was left of the original foam from mine but never insulated it afterwards. The engine noise doesnt bother me. West marine sells engine box insulation.
Old 03-05-2017, 09:31 AM
erebus erebus is offline
Sounddown acoustic insulation.
Works really well. The thicker the better.
Not cheap tho...
https://www.jamestowndistributors.co...ct.do?pid=9345
Zachary
Old 03-06-2017, 08:52 AM
more work , the balsa was soaked with water going to remove and use divinecell for core
Old 03-06-2017, 08:55 AM
this is what caused problem
Old 03-06-2017, 09:01 AM
hull and deck putty and divincell
Old 03-06-2017, 10:15 AM
thanks for the info erebus
Old 03-06-2017, 11:02 AM
bigeasy1 bigeasy1 is offline
I also used Mertons hull and deck putty to bond balsa core to the completely rotted out engine box On my Tsunami.
I used soundown 1-1/4 sound deadening insulation.
As mentioned, it's kind of pricy and it's also pretty heavy. As for its sound reducing quality, I found it to be ok but expected it to perform better.
Don't get me wrong, it does reduce the noise significantly when trolling or motoring at mid to lower engine rpm's but when I run at higer speeds (like hour runs to a fishing spot) I use disposable soft foam earplugs that only cost pennies.They work better than anything.
I bought the Soundown direct from them, but they protect their dealers (understandably) so its actually priced equal to any of the boat or marine supply dealers like Jamestown dist. Hamilton Marine out of Maine stocks it in many thicknesses and sizes and ships everywhere.
All this,just for a boat ride
Old 03-06-2017, 05:26 PM
abl1111 abl1111 is offline
I had (2) i/o's and converted to (1) i/o - so, I cut the engine box and removed a 12-14" section from the cover - re-glassed well AND glassed-in a wood support from port to starboard, more aft, for my 35-40 gallon live well I store up there from time to time. I added the sound stuff Erebus mentioned - and it keeps the engine real quiet.
Old 03-06-2017, 09:13 PM
FAS FAS is offline
some of the shiny insulation stuff has a lead core ,really do not need that for a gas engine,[mostly diesel].otherwise it's not too expensive, looks and works well..although, far from original stuff.if that is important to you
