Old 06-16-2017, 05:47 AM
TJS TJS is offline
Default 1977 23 sf
-full transom
-Hermco bracket
- Alwgrip inside/outside Snow White
-ttop and console from a 24'silverhawk
Finishing some rigging. Console wasn't set yet in pic looks a little to forward.
Almost ready for the Cape Cod waters
Old 06-16-2017, 06:48 AM
I wouldn't rush into moving the console & leaning post back too far. Can't say enough about having lots of fishing room. With the ride these babies give, having the console a little forward isn't going to affect the ride THAT much, IMHO. Especially if there's a 4 stroke going on it. Looking Good!
Old 06-16-2017, 09:16 AM
BA17 BA17 is offline
Looks great.
Old 06-16-2017, 02:36 PM
Default Console Location Effect on CG
Suggest you look at my post of 9-24-16 on ESTIMATING CG SHIFT WITH HEAVY ENGINES as well as link to the example to give you an idea of affecting cg. If you choose to move the console aft you might compensate by relocating something else like batteries or the seat for your robust friend. The example should be easy to follow by changing my values to yours- no hard math.
I admit based on what we normally see the console in the photo looks forward where the ride wil be slightly rougher but probably less spray.
Old 07-02-2017, 06:43 AM
TJS TJS is offline
Some recent progress. Some wiring and rubrail left. Anyone have any tips on bending the 3/4 taco stainless insert around corners. I will be installing that next Sunday. Any insight would be helpful.
Old 07-02-2017, 03:36 PM
SS Rail should be cut into 5 pieces. MEASURE FIRST.
Do not cut at same seams as the rubber rub rail. SS insert should overlap all rubber cuts.
Piece 1 start at nose with a screw hole just shy of dead center and measure approx 6-7 screw holes port & starboard sides to foward of the foward vents. Screw rail insert as you .
Pieces 2 & 3 port & strbd sides run aft to approx to the rear of the rocket launcher .
Pieces 4 & 5 screw as you go, make aft corner bends and have pieces meet at center line transom mark ..pieces should over lap a few inches in order for a precise seam trim.
A rubber mallet may assist you . I don't know how long each strip pieces you bought so measure them with a fabric tape first and verify.
I hope this helps
Old 07-05-2017, 10:04 PM
Wooley Wooley is offline
Originally Posted by TJS View Post
-full transom
-Hermco bracket
Awesome boat !
Old 07-10-2017, 09:00 PM
TJS TJS is offline
Boat is finished. Great site guys. Very helpful. Lots of nice boats. I am going to splash her this weekend. First Seacraft I have owned and am in love already.
Tyler
Old 07-11-2017, 08:30 AM
Wait until you run it across the chop -
There're "Cross Tie Walkers"
Old 07-17-2017, 07:32 PM
Wow TJ your boat came out amazing!! Imho a White Rubrail with a Stainless Steel insert gives Seacrafts a very sheik, classy and sexy finish! I have a similar Taco on my 23 and have another (small size) going on my 18 SC. Looks awesome mane! Love it!
