Old 08-12-2017, 09:24 PM
sisu22 sisu22 is offline
Default Outriggers for Sceptre
Any one. Know what came with boat in 1973 ,I have what looks to be orginal gunnel mounts and and need outriggers 1.75" 16' 18' 20'.any help appreciated
Old 08-12-2017, 09:48 PM
Actually nothing probably came with the boat new, they were an add on by one of the owners. Google "gunnel mount outriggers", all the options you will need to know. Do you know if the bases are Lees outriggers? However if you want to go crazy, check these guys out....
https://www.marshtackycarbon.com/
Old 08-12-2017, 10:15 PM
They look like Lee's but no logo on them .carbon fiber is crazy
Old 08-12-2017, 10:28 PM
FLexpat FLexpat is offline
My 23 Sceptre came from the factory with 18' Lee aluminum gunnel mount outriggers.
Old 08-13-2017, 07:59 AM
Default Outriggers
A zoomed in photo of your outrigger bases might be helpful. Don't remember the make offhand. About 1977 I bought my stainless steel bases and probably separately purchased two piece fiberglass outriggers with a tubular upper and solid lower piece.
Old 08-13-2017, 12:39 PM
Yes Sir!! Very much crazy!
Old 08-13-2017, 02:28 PM
caper caper is offline
Good luck. Had same thing going on with my 1975 23SF. Found that outriggers were not the problem - bent tubes to fit the gunnel mount and the newer outriggers were the issue. My gunnel mounts were Lee and Lee no longer makes a bent tube to fit. I believe that back then the 45* bent section was part of the 1 1/2" one piece outrigger. I ended up changing to newer gunnel mount.
