Old 08-16-2017, 07:00 PM
Jonhybrid Jonhybrid is offline
Default Brace for newer heavy motors
I bought an 88 20 cc about 6 months ago. After reading on how heavy these newer 4 strokes are and these hulls were designed for lighter 2 strokes I felt I should add a brace to the transom to help spread the weight. I now love the boat more and feel more confidence with the extra weight and it being a 30 year old hull. I also moved the motor up one bolt hole and it runs a higher WOT and ever a little better fuel economy. Love this boat more with every modification.
Old 08-16-2017, 07:42 PM
1.) If your going to slap a heavier motor on, you will need to replace your 30 year old transom .
2.) The rigging tube , fuel line, steering etc needs to be moved up about 4" & sealed. That rubber boot setup is not waterproof. Backing down puts your integrity at risk.
Old 08-16-2017, 09:01 PM
Thanks for your info. The transom is solid it was checked, the brace was for my piece of mind.
Old 08-16-2017, 09:33 PM
A brace is added.
Old 08-16-2017, 10:27 PM
I've seen that brace with seacraft name on it and I plan to put one on mine
