Old 09-01-2017, 08:17 PM
StregaP51 StregaP51 is offline
Default I think I might have a fill hose leak?
2002 21 CC. Just bought this boat about 3 weeks ago. I bought it with about a 1/2 tank. Today I put 20 gals. in with Valve Tec. Launched the boat and ran it for about an hour. There is defiantly fuel in the bilge. So I assume the fill hose has a leak. I can't understand why SeaCraft ran the fill so far FWD. Anyway what is involved checking the hose and or replacing it. Thanks,Dave
Old 09-01-2017, 09:01 PM
Defiant fuel can ruin your whole day.
Forevah.
Old 09-01-2017, 09:30 PM
Well did you notice they put the pick up tube in the rear of the tank? There's a reason the fill is in the front, most boats sit with the bow up. Now the bad news.....you might have put enough gas in the tank to go above the level of a hole in the tank, therefore gas in the bilge.
Old 09-01-2017, 09:37 PM
Happened to me. Salt water ran down the riggin` hole.
Old 09-02-2017, 10:19 PM
That's comforting. I'm thinking it might be the hose. Only because if it was the tank I would think it would be still leaking in the bilge. Wishful thinking!! I'm going to pull the fill neck flange to see if I can see anything.
Old 09-03-2017, 02:24 AM
I'll make no assumptions, and will hope it's just a hose -- but do re-read and assess Don V's post (the bad news part).
Old 09-03-2017, 07:37 AM
riggin hole??
Old 09-03-2017, 10:00 AM
riggin hole??
The hole in the deck under the console where the riggin` goes to the engine.
Try and remove the fill fitting screws. Do all but one come out? If so one on the screws is a machine screw with a nut on the backside.
Old 09-03-2017, 11:56 AM
That's what I plan to do next. Probably this afternoon when it stops raining. Why would they nut and bolt it. Really! Thanks for the heads up.
Old 09-03-2017, 02:27 PM
Green ground wire to tank from fill.
