Old 09-27-2017, 09:43 AM
ericallen01 ericallen01 is offline
Default 23 Tsunami Hull Moisture + Flex
Hello CSCers,
I am going over a 1974 23' Tsunami (Sceptre), 1-owner, I/O, and have found some unusual hull flex and moisture readings that don't appear on a similar boat I own.
The moisture and flex is between the inboard and outboard strakes, and begins about 3 feet forward of the transom, increasing toward the bow.
Is this a design feature (light construction)?
Can anyone point to a cause for high moisture readings in the SC glass hull?
The boat still rides fantastic.
Thanks in advance
Old 09-27-2017, 10:00 AM
How are you seeing the flex? What methods are you determining excessive moisture? I just went through my 74 Tsunami hull and the hull layup seemed unnecessarily heavy. I'm wondering if the hull you are looking at had been submerged or flooded for a duration of time.
Old 09-27-2017, 10:26 AM
FLexpat FLexpat is offline
X2.
It sounds like where you are seeing moisture/flex is where the stringers are - if the foam in them is saturated with water it might explain the moisture readings but I don't have a clue about the flex.
Old 09-27-2017, 11:10 AM
bgreene bgreene is offline
Typically.........flex / softness = deteriorated structure usually caused by the affect of water on wood over the long term.
30-50 year old boats.......regardless of brand were built with a lot of wood.
Some were properly sealed with epoxy to last longer, some not and deteriorated faster.
It is what it is. Be careful.
Old 09-27-2017, 02:57 PM
I found the same thing accidentally (and repaired it) when I replaced my fuel tank. This partially has to do with the way the hulls/stringers were laid up and 40+ years of freezing and thawing cycles (some without a tarp/cover). I hope you don't have the same problem, but I'd be willing to bet this is the issue. It's easier to repair from the inside even if you sawsall through the hull like I did. I have 130+ hours on the boat now after the repair (in some real nasty conditions) and the repair is holding up great.
http://www.classicseacraft.com/commu...t=28644&page=5
Old 09-27-2017, 03:20 PM
Didn't even think about freeze/thaw busting the stringers loose. Makes sense.
Old 09-27-2017, 03:31 PM
Total sense. Us Florida folks know nothing of the hazards of freezing boats.
Old 09-27-2017, 04:14 PM
What the hell is a freezing boat? I know about freezing fish, things like that, but a boat should not be freezing!
Old 10-01-2017, 10:23 AM
Thanks for everyone's comments. I agree busted stringers would be most likely behind the hull flex.
Going to investigate further. Think the boat may have grounded pretty hard once, maybe this created some cracking / openings for freeze/thaw damage. Opening it up this week.
