Old 06-10-2018, 08:31 PM
Gmoney28 Gmoney28 is offline
Default 23 ft.spectre sea craft
Can any one tell me how the scuppers work on this year boat, should I worry about rot in the scupper to hull connection ?
Old 06-10-2018, 10:48 PM
Need to know year of manufacture; later years (1980's and after) were built differently, if I remember correctly (after Bill Potter sold SeaCraft).
Old 06-18-2018, 08:03 PM
bgreene bgreene is offline
Guys on this site can guide you ......water apparently does come in through the scuppers.
Some install a blocking system, others re engineered by raising the floor and re routing the scuppers.
Regarding rot......not qualified to address but you'll find your answers here.
Old 06-20-2018, 03:45 PM
bigeasy1 bigeasy1 is offline
If your scuppers go thru the deck floor, prepare to have water come in when you're at trolling speed and a couple people are in the stern netting or gaffing a fish.
At least this is what happens in my 23 Tsunami (aka sceptre) when two of us are in the stern netting a fish.Once we move back to the front the water drains right back out.Its not a horrible issue but it is a bit of an annoyance. I should add that my boat is an I/0 with a 5.7 mercruiser and the boat squats low in the stern
I took some thin wall tubing about 3" long and placed a cut off hinger from a nitrile glove and stretched it over the tube and cut the bottom off leaving about 2" of the finger.It works like a duckbill, closing when water tries to enter from the lake or ocean and opening when water is draining from above such as when you use the washdown. All you need to do is place this tube with finger into the scupper.
It actually works surprisingly well and it costs almost nothing to make.I use 3/4" copper tube as I fish fresh water, plastic tubing or stainless tube might be better in salt water.Keep a few of the gloves on board in case you need to replace one.BTW, the middle finger works best as its longer than the others.
I use electrical tape to hold the finger in place on the tube and it also helps keep the tube secure In the scupper
Its kind of a caveman fix but it works very well.
All this,just for a boat ride
