Old 09-17-2018, 09:43 AM
crsavage1 crsavage1 is offline
Default Flats trailer?
I am still looking for a new trailer for my 19' SeaCraft with a bracket. Found a nice aluminum BoastMaster trailer. Apparently flats boats have 22 degree bottom vs 24 on a classic SeaCraft. I am struggling to understand if trailers will fit (or could be made to fit) my boat from a bunks perspective. It's a tandem and can handle the weight...am I over complicating this? Thanks for any insight.
Old 09-17-2018, 10:03 AM
Yes you are. Flats boats are closer to 10 degrees at the transom....or less. 95% of all trailers made there are adjustments built in to fit many different boats. If it's the right length and capacity adjust the bunks and go. Oh yeah, the last three trailers I've helped rebuild, including mine, I cut the rear bunks at 15 degrees and it's worked perfect. Good luck.
Old 09-17-2018, 10:14 AM
Thanks DonV. I tend to over think and end up making things dumb. I sincerely appreciate the advice and insight.
