Old 09-22-2018, 06:36 PM
Default 1980"s era 20sf's
I should know this but just wanted to check with the pro's...I think I remember hearing that the later 80"s 20sf's are slightly longer then the earlier Potter era models? I see on the net where some are calling them a 21 rather then a 20. Also I remember something about a hook in the hull...I think that was on a 23 mold. Any thing in particular to watch out for if one was to re do a later 80's 20sf? Sandy I know you have one...
Old 09-22-2018, 06:52 PM
Hook was on the port side Sceptre 23'. After CSY around 1983 as I remember. I don't recall the 20' had changed in length ?
Old 09-22-2018, 07:30 PM
Default Sceptre Hook
If you search Bushwacker had some posts describing the hook. Don’t think it was on very many.
Old 09-22-2018, 09:17 PM
Doc, a 20 is a 20.
Nice to have you back.
Do you want my 20?
Old 09-22-2018, 09:24 PM
FLexpat FLexpat is offline
GFS will know for sure but I think you are right. My recollection is that the Tracker era(?) 20s were about 6" longer and had a slightly higher deck. The only hook I know of was on the 23 as Capt Chuck mentioned. I remember hearing about a slightly shortened 23 being sold as a 21 but that may not be accurate or it could have been a one-off; the beam would be the giveaway on that.
Old 09-22-2018, 09:45 PM
Joe R Joe R is offline
I have loads of old brochures at my office , but they made a 20 that was a bit bigger than the potter 20...but not a tracker...and they also at one time advertised the MA as over 20. If I remember I look over the brochures later
Joe R
21 SeaCraft 1998
Susie 2
Joe R
Old 09-22-2018, 10:00 PM
The 80's were 20 4" and the 70's were 19 6"
Old 09-22-2018, 10:14 PM
SCI raised the deck of the 20.
Mid eighties.
Old 09-22-2018, 11:10 PM
All very informative replies Thanks fellas. I've only seen one 80's 20 sf and it seemed a bit longer then the 69 20 sf I rebuilt several years ago. I did not measure it. Just doing some research and catching up. I have not been out on my boat in a very long time...It's ready to go for a short shake down cruise when I get the time. Bunch of other projects are keeping me off the water.
Old 09-23-2018, 06:36 PM
There is also a short spray strake under her nose.
Maybe they extended her beak a few inches???
