Old 12-28-2018, 09:21 AM
Default Keep it original?
Started ripping in to my '78 23' center console yesterday. I got the t-top and console out and all hatches removed. I've got the head console with the removable tub recessed under it. So far the only repair needed seems to be weak spots in the deck. My question is whether or not to keep it original or change it up. Is there any value in keeping things as Potter intended?
Old 12-28-2018, 11:46 AM
bmajvi bmajvi is offline
Interesting question. Of course in cars there's value in keeping things stock during a restoration not sure that's the case with SeaCrafts if the mods are well thought out and executed well.
1977 23' Sceptre
Old 12-28-2018, 01:07 PM
Default Make it yours
I largely agree. My 42 year old Seafari is mostly original. Chgd some trim added things like swim platform, etc. it’s not like the Corvette competition where my buddy lost points for the wrong air filter wing nut. Some bad mods could adversely affect desirability.
Old 12-28-2018, 05:57 PM
cdavisdb cdavisdb is offline
These boats are very well laid out, often in subtle ways. Mine doesn't look all that different from my last boat, but it sure works better. Things are put in better places, etc. I've made some minor mods, but if I can't see a definite drawback to the original, it stays that way.
Modifications can make perfect sense, but make sure you understand your needs and have thought out exactly how the mod will work.
Old 12-28-2018, 08:21 PM
1,000 hours Imagineering= 100 hours of actual work.
The boat is yours. Build it out for your wishes and desires.
Old 12-28-2018, 10:46 PM
wgscott329 wgscott329 is offline
Are you cutting the floor out and replacing it or fixing the soft spots as is?
Old 12-28-2018, 11:15 PM
Just saw your other thread about cutting up the floor and checking fuel tank.
http://www.classicseacraft.com/commu...ad.php?t=29602
This is what I did to mine to give you ideas about what you could do to yours. The changes I made to mine greatly improved the boats ride quality, gave me tons of under deck storage, brought the boats CG much further forward than the original layout, made space for an easily accessible bilge area, and raised the floor in the back so it stays dry. All that said, most of these improvements can be made without changing the original stringers, and I wouldn't change them unless you really have to or really want to for the under deck storage.
Old 12-29-2018, 09:13 AM
Thats an awesome rebuild! I'm debating how far to take this.With a new 250hp and steering running about 20g's I am definitely limited as to my repair budget. If I remove the tub under the console I would lose storage but I could move the tank forward.How much do you think that would affect the ride and wet feet factor? Also thinking about raising the transom to 30".
Old 01-01-2019, 07:00 PM
Got my deck all cut out today and have some questions. I left a 2" lip around all sides to attach the new "cleat" for the new deck but the core thats left in the 2" piece is wet. What to do now? The Potter putty that is left on top of the stringers looks like it serves as a leveling tool as well as an adhesive so do you want to remove it? The rear half of the deck was cored with end grain balsa and the forward with plywood 1/2". Is this the norm?
Old 01-02-2019, 11:13 PM
You might be able to skim off the top layer of glass right where it makes the turn up to the sides of the liner. Take out the bad core, and then make your new floor to fit over the bottom layer of glass remaining. You probably need to take all that potter putty off. Its a pain. Moving the tank forward probably won't lift your stern all that much, I would bet 1/2" or less. most people raise the floor about 2-3" to solve the transom water issue. If you want to do this you'd have to flatten all the potter putty anyway to be able to evenly heighten the stringers, and your floor would be hitting the liner 2-3" higher, so the lip you left around the edge would be irrelevant at that point.
