Old 01-10-2019, 12:53 AM
Jtr Jtr is offline
Default 1986 23’ seacraft walkaround
Anyone know size of fuel tank? How many gallons? I think it’s 96”x 27” but don’t know depth or configuration. Any help greatly appreciated!
Old 01-14-2019, 07:26 PM
I replaced the original tank in my 1988 23WA with a new tank of the same dimensions. The new tank is labeled 115 gallons.
Old 01-31-2019, 11:07 PM
Jtr Jtr is offline
Thanks for responding. Do you know the depth of tank and who built it? I guess I will have remove bridge deck to pull tank or were you able to slide it out?
Thanks
Old 02-01-2019, 08:50 AM
rcnight rcnight is offline
I’m replacing the transom on mine. Decided to go in from the inside because I wanted to pull the tank as well. Cut the last 20” of cap off which made access to the tank much easier. Not sure if you can pull it without a little deck surgery. The angle might be too tight if pulling it out from the hatch. Whichever way you go, blast the foam out with a good pressure washer - makes it much easier to pull. Capt Lloyd might have better advise. Good luck.
Old 02-03-2019, 11:26 PM
Sunshine Welding in Port Canaveral built my tank, sorry I don't recall the depth of the tank. I cut out the motor well in order to remove the old tank. And there is a bulkhead at the aft end of the tank that I removed. Good luck!
