Old 02-24-2019, 06:09 PM
Seacraft1974 Seacraft1974 is offline
Default Gouge in bottom
I just purchased my old Seacraft back after 8 yrs. it appears to have a gouge from the trailer the previous owner was using. It's about 1/4" wide x 6" long. It went through the bottom and I can see the glass. I may be seeping. It's right alone the stringer. What's the best way to repair? After the summer I will have a complete redo on the entire boat so I'm looking for an easy but safe "patch" idea.
Old 02-26-2019, 12:04 AM
Thru the bottom or thru the gelcoat and into the fiberglass?
Old 02-26-2019, 09:30 PM
Its through the gel coat. I can see the fiberglass. It's minor but needs a patch. Again in Oct I'm having the entire boat refurbished
Old 02-27-2019, 07:24 PM
Thickened epoxy would be my fix
Old 02-27-2019, 09:53 PM
Kraken Kraken is offline
Clean it good and remove any loose gelcoat. Scuff it up with 120 grit paper. Wipe with acetone. Use a acid brush to paint in some gelcoat. Sand as smooth as you wish. Will seal it up and last a season.
If you uses epoxy, you can’t go over it later with gelcoat. Won’t stick.
Old 02-27-2019, 09:58 PM
Cool. Thanks I'll try it
Old 02-28-2019, 05:01 PM
That is good to know!
Old 03-21-2019, 08:49 PM
FLASHBACK FLASHBACK is offline
Any idea who sells a good color match for white Sea Craft 1973 (Seafari 20')?
Paul S. Hoffman
FLASHBACK
20' SeaCraft Seafari
Boca Raton, FL
