Old 03-25-2019, 11:09 PM
Jfd Jfd is offline
Default In floor baitwell 2005 seacraft 23 cc
Very pumped to have Just purchased new to me 2005 seacraft 23. Generally in great shape but still figuring out some of the features and systems. Is there any way to get an operators manual? Would really appreciate some input on how the fill and pump out of the in deck bait well works. Boats currently on the trailer at my house and I won’t have time to get it in the water for at least a few days. Appears filling requires removing floor hatch between the bait well and transom and opening valve to through hull inlet through bottom hull. Is this correct? This seems combersom and could cause major problem if valve was accedntly left open could this flood the boat? Maybe it’s designed so water only goes to certain height such as water line. Orr part of question is how is water drained out? Viewing plumbing appears the water is removed by pumping out. In my boat appears that pump is just not working. There is a switch labeled “bait well pump out” but when pulled down nothing happens. All other switches/pumps seem to work. I have pictures I could post if that helps.
