Old 05-09-2019, 12:24 PM
budd409 budd409 is offline
Default SeaCraft 20 Classic Center Console 1973 Potter Hull $34,800/SOLD
Total rebuild 2014-2015. 285 engine hours ago. The transom was filled in and a Armstrong bracket with S/S ladder installed.
The stringers were built up 3" to make the boat self bailing. A new deck was glassed to the liner. The liner was then glassed to the hull to increase strength. A new 60 gallon tank was installed after being epoxy coated by the builder.
A built in spray extends half way on each side.
The 2013 150 hp 4 stroke Suzuki is covered by the Suzuki warranty until 10/28/2019. Annual service was just performed on the engine.
The hull is painted with Algrip in Seafoam Green, the liner is also Algrip in Oyster White. Botton is Petti Vivid White.
A specially sizes console was built by Wildfire Marine in Stuart, Fl. This 28" wide console allows easy passage on each side, yet provides plenty of room for electronics and storage. A four drawer cabinet on the port side allows more storage.
The T top and leaning post were constructed specifically for this boat. The top is fiberglass and has 4 rod holders, outrigger mounts, light mounts and mount for the radio antenna, The Garmin GPSMAP 700 series serves as a chart plottter and depth recorder. A Garmin 100 VHF complete the electronics. Both are mounted inside the console along with the Suzuki Gauges (rpm, fuel, voltage, water pressure) hour meter, circuit breakers and 12 volt outlet. Lenco trim tabs 9x12 and retractor are controlled at the helm as is the bilge pump switch.
The salt water wash down pump supplies the live bait well. The bilge pump and float switch are easily accessable thru a floor hatch.
A custom made Sunbrella cover and dual axel aluminan trailer are included. budd409@aol.com text 561 779 2482 PayPpal#15893110C9884804C
