Old 06-12-2019, 01:40 PM
castnetcracker castnetcracker is offline
Default Suzuki DF350 #'s
So I'm almost finished with the first 10 hrs on the engine and figured i'd post up some performance numbers on the Boat/Engine. I'm very happy with the performance of this engine and the 23 seacraft. I hadn't ever ran one before i pushed mine off the trailer and fired up the engine. I think it may benefit from raising the engine up to the last hole on the bracket and may need to go up a prop size after the rings fully seat but I really dont think it's worth the expense of 2 new props for a small gain.
1979 23' SF - Suzuki DF350A
Prop: 15.5 x 24 duoprop
Mount: Hermco Twin engine bracket mounted 1" higher than instructions (top of platform 27" above keel)
Fuel - 90 Gallons (104 gal tank) 90 Octane ethanol free
Weather: Glass calm conditions, 90 degrees
5 adults and minimal gear, T-top installed
3300 RPM - 30 MPH - 7.93 GPH - 3.8 MPG
3900 RPM - 36 MPH - 10.3 GPH - 3.5 MPG
4600 RPM - 43 MPH - 15.0 GPH - 2.9 MPG
6300 RPM - 59 MPH - 29.8 GPH - 2.0 MPG
Whats interesting, is that with 20 gallons of fuel and only me on board i get the same Max speed of 59 which is what leads me to believe it may need more prop.
Old 06-12-2019, 05:13 PM
Sounds like a nice sled. Sounds like there is a little more in it yet maybe. No bad #'s at all.
Old 06-12-2019, 07:03 PM
Let's see here, 30 mph at 3300 rpms at 3.8 mpg....with five aboard??? I would be ecstatic!!! Well done
Old 06-12-2019, 08:50 PM
Those are some outstanding #s for sure.
Old 06-12-2019, 08:57 PM
NaturalHigh NaturalHigh is offline
Default 350
How is the stability and how does it go in reverse
Old 06-12-2019, 10:17 PM
Sweet! I need one of them 350's
Old 06-12-2019, 10:35 PM
3900 RPM - 36 MPH - 10.3 GPH - 3.5 MPG with that load is amazing!
Old 06-13-2019, 04:17 AM
Great numbers! Where are the pictures? So I guess a spare prop means both?
Old 06-17-2019, 01:01 PM
captainDH captainDH is offline
incredible numbers! bigger is better!
Old 06-18-2019, 12:22 AM
Briguy Briguy is offline
WOW! Same MPG or better than my '79 with a new 300. And you are pushing 60 which is crazy. She's about 6mph faster across the board at the same rpm's.
Tempted!!!!!!!!!!!!
Capt. Brian
