Old 08-04-2019, 07:08 AM
Bigsean Bigsean is offline
Default Trim Tabs for 23' SF
Hey Gents I just purchased a 77' 23' SF..I have a Armstrong bracket so space might be a issue.. What trim tabs are you guys running..I have a good lead on the bennett m120 system..Any advice or info would be greatly appreciated!
Sean
Old 08-04-2019, 07:14 AM
Check out the Bennett Bolts 12" x 12"s, they have the best vertical clearance for under a bracket installation.
Old 08-04-2019, 09:01 AM
Default Tabs
The Bennett m120 system is a 10 x12 tab with a short actuator for clearance.. how do you feel about this?
Old 08-04-2019, 09:04 AM
Oldboat Oldboat is offline
With my bracket set up for 30 inch shaft I used the 12x12 with 11 inch clearance. My brother in law has a 20 seacraft with a Armstrong set for 25 inch shaft and he also used the 12x12 lenco s with 11 inch clearance and they just made it with out trim. If it were me I would mark your bracket on transom along with tab locations and adjust as needed. Lenco ask for 3/8 off bottom u could use a little of that if u need it to make it. Hope this helps
Old 08-04-2019, 09:07 AM
As a note I’m having porposing I’m trying to dial in will keep u posted
Old 08-04-2019, 09:12 AM
Another pic
Old 08-04-2019, 09:17 AM
The Bolts will spoil you for ease of installation versus the hydraulics and the extra hardware. Plus the Bolt actuators are a lifetime warranty. Either are a good choice.
Old 08-04-2019, 10:42 AM
Old Goat Old Goat is offline
DonV,
Are the Bolts units all electric, IE no hydraulics?
Charles
Old 08-04-2019, 10:57 AM
Yes Sir. I've helped install two sets and it's all electric. One wire for each actuator to the switch and 12v power, pretty much "plug and play". The one feature that some like and others don't is the auto-retract when the key is turned off, I assume it's an optional feature not sure. Nice if you have a trailer clearance issue and forget to retract the tabs at the end of the day. However, as an example, on a skiff they are a bit noisy if you are idling up on fish and turn off the engine they make a bit of noise going back up. Plus if you have your tabs "dialed in" most would rather have them stay in that position until done for the day. Personal preference.
Old 08-04-2019, 11:38 AM
Thank you, Sir.
