Old 09-27-2019, 09:58 AM
plusone876 plusone876 is offline
Default Wood in a 1971 20 SF
What parts of the hull are wood? I know the transom, floor (core), hatches (core), and various other areas have wooed but wanted to confirm. Stringers?, cap, liner, etc.?
Thanks
Old 09-30-2019, 02:34 PM
Anyone?
Old 09-30-2019, 03:47 PM
I don't think the stringers do at all. Glass filled with foam. Probably wet foam for a '71.
Old 09-30-2019, 10:05 PM
Joe R Joe R is offline
Deck. Transom . keel, stringers are hollow but may have a piece of wood in them that was used as a form during construction
Joe R
21 SeaCraft
Susie 2
Joe R
Old 10-01-2019, 03:32 PM
Thanks. Any other wood. Core of cap, hatches, etc.?
Old 10-01-2019, 06:08 PM
JohnC JohnC is offline
Cap coring is wood, deck coring is wood, plywood cored transom & some kind of hardwood in the keel (looks like fir to me). Some of the inboard models had some pieces of wood in the stringers to bolt motor mounts to. That's it!
Hull and stringers are resin & glass - no sandwich coring at all. in 1971 I believe that you have 4 hollow stringers - They look like they were made in a mold and then tabbed into the hull (hollow), no foam filled box stringer like the later models.
Quick edit - the cap coring I have seen is in later model MA boats. I don't know if the cap in the 2-piece hulls is cores or not. If you pull a rod holder out you will be able to see it.
Old 10-09-2019, 09:05 PM
Andrew Hill Andrew Hill is offline
X2 on what John Said. I just dove into a 71 20 SF and found wood to be in keel, and hollow stringers throughout
