Old 10-18-2019, 10:14 AM
captsuperfly captsuperfly is offline
Default trailer bunk fit - 23 SF
I just got a good deal on a clean load rite aluminum bunk trailer that was used to carry a 23 Regulator (24 degrees deadrise). I'm hoping to use it to carry my 23 SF.
The main bunks are set up on their sides, so an angled side edge would rest against the hull. Aside from sliding the bunks across the crossmembers to fit the hull, there is no adjustment to change the angle of the actual bunk on the resting edge (unlike some bunks I've seen that rest the face of the bunk agains the hull and can pivot to adjust for dead rise.
I am adding some front centering bunks which will be easy enough to adjust.
I'm tryin to determine if I'll need to re-cut the angle on the bunk to accommodate the difference in dead rise. Does anybody know the dead rise angle of the 23 SF hull just inside of the chine where the bunks usually rest? Has anybody gone through this?
