Old 01-28-2020, 08:03 AM
TMala TMala is offline
Default Coosa board for SF20
Hi all,
I am debating on going with coosa vs a pourable type of composite for my transom on my 69 SF20.
As far as I can tell coosa does not sell a board at 5/8in. I can get two at 3/4 or one at 3/4 and one at 1/2. Being i'm using coosa over traditional ply could I get away with using a 1.5in core and not adding so much glass to the inside skin (I'm building from the outside) I also don't need the thickness of the layer to laminate the ply's together.
The plywood that came out of the transom was two pieces of 3/4, so it was redone over the years but the inner skin of my transom was paper thin, ideally I would have one at 3/4 and one at 5/8 so I can add to the inner skin but I would rather use a composite over traditional plywood.
OR I could beef up the inner skin build the outer skin and pour in some ARJAY and be done with it. The only problem is i'm trying to get quotes to ship the stuff to NJ and i'm guessing it's not going to be cheap, it also is heavier than coosa and I have no intentions of raising my deck. Coosa on the other hand I can probably pick up as compositesone in NJ and have it by the weekend.
Old 01-28-2020, 08:09 AM
Seems I just found 5/8 listed from a different distributor, I guess I didn't search hard enough
Old 01-28-2020, 02:54 PM
I would match core thickness after beefing up the inner skin. The outer skin being off already means youre glassing and fairing anyhow so build that up as much as you want...
I only saw 1 pic on that link, can ya take some more??
Old 01-28-2020, 03:36 PM
These are the only ones on my phone, I can snap more when I?m home. I really screwed my self by not leaving a lip for the scarf, I really just attacked the transom without thinking of leaving more room until I stepped back to look at it lol.
The plywood there is a sample of what came out.
The new transom will be composite either pourable or coosa.
Old 01-29-2020, 11:05 AM
Last question! I’m back to square one, coosa is hard for me to find, but my local fiberglass supply has Penske in 1/2 and 3/4 with not 5/8 option. I would like to give them my business. Would putting two in at 3/4 or one at 3/4 and one at 1/2 be an option for me if I add extra glass in the end? What’s everyone’s thoughts on that? Two at 3/4 came out with a thin inner skin, if I put two 3/4 Penske it can’t be any worse than what came out right?
Old 01-29-2020, 12:41 PM
smilinmatt smilinmatt is offline
I'm assuming you don't want to work from the inside of the boat, so if your options are 1.25" core plus a lot more inner skin glass or only 1.5" core, I'd go with building up the inner skin and a thinner core. Penske (or any structural foam) has a fraction of the compressive strength of plywood, so you'll want the extra glass on the inside to help distribute your outboard's fastener load.
Old 01-29-2020, 01:56 PM
The problem now is tying the outer skin back into the hull. Without a total deconstruction of the inner skin youre kinda stuck with beveling and tabbing the outer skin to the outside of the hull. If youre doing that, the thickness doesnt have to fit back into what was originally there, you can build it to whatever you wanted.
Old 01-29-2020, 02:02 PM
So use two at 3/4 destroy whatever lip I have remaining on the outside and wrap around to the hull sides? I’m ok with that as I was thinking of painting the hull in the future anyway, and it will allow me to get a 12:1 scarf. I think I have to wrap to the hillsides anyway I really screwed that one up! So many ways to skin this cat.
Old 01-29-2020, 02:15 PM
So use two at 3/4 destroy whatever lip I have remaining on the outside and wrap around to the hull sides? I?m ok with that as I was thinking of painting the hull in the future anyway, and it will allow me to get a 12:1 scarf. I think I have to wrap to the hillsides anyway I really screwed that one up! So many ways to skin this cat.
The sides aren't really a problem, other than fairing it out to look good. If you have to wrap around the bottom though, that'll create a hook that could cause real performance problems.
Old 01-29-2020, 02:41 PM
Good point, it could be tough to get that right. I will measure the lip I left, I know if my laminate is 1/4 in thick 12:1 would be a 3 in scarf I will measure and check if I have that.
