Old 04-05-2021, 01:13 PM
edloh edloh is offline
Default Seacraft 18
Anyone nice enough to share stock picture of a 18ft? Are the deck self bailing on the 18?
Old 04-05-2021, 01:46 PM
http://www.classicseacraft.com/commu...1&d=1617644324
This is all I have before restoration.
http://www.classicseacraft.com/commu...1&d=1617644700
And after. It self bailed from the factory I'm sure, but not with the 4strokes unless you shift weight.
Old 04-05-2021, 01:47 PM
I must have a pic labeled wrong.
http://www.classicseacraft.com/commu...1&d=1617644826
Old 04-05-2021, 03:54 PM
steel686 steel686 is offline
My ETEC is roughly same weight as uncleboo’s DF140. Shaved weight and shifted tank forward. I chose not to raise deck height and it self bails. Read a few 18 threads and you will get good info. You have pics?
Old 04-05-2021, 08:05 PM
Thanks for the poc and feedback.
Unclebok.. original have a a curve fixed motorwell that you cut off correct?
Old 04-05-2021, 09:46 PM
I have a totally stock 18 with a 2009 90 HP Mercury and it self bails. It has about an 1 1/2" between the scuppers and water.
Rod
Old 04-05-2021, 10:29 PM
rod
does the stock have the slope motorwell that goes over the live bait tank in the floor?
Old 04-05-2021, 10:45 PM
I have seen pictures on here of the molded splashwell if that is what you are talking about. Do a search for that or just a google search for 18 Seacraft and I bet you will see that. Mine had a glassed-in version of that when the previous owner ran scuppers through the bottom of the hull. It would fill if you stood in the corners. I tore that out and ran them out through the transom like original. I put a lot of time into restoring the gutters and reworking that detail. I pitched the inside of the motor well to eliminate standing water and will still put ping pong balls or flaps this spring.
Old 04-05-2021, 10:54 PM
One more. Original gutter exits where circled. 9 or 10” splash board is new obviously. You can see the old holes in the outside corner. I think the splashwell part you mention was an option from the factory. Someone correct me if I am wrong.
Old 04-05-2021, 11:42 PM
Nice boat.
Yes the splashwell. Do you raise your transom to 25in and it clears the splash board tilted up?
