Old 07-24-2021, 07:02 AM
bmajvi bmajvi is offline
Default Bennett "Bolt" Electric Tabs?
Our 23' has non-working 40 year old Bennett hydraulic tabs, and it seems like the pump is shot. The switch is antique too, thinking about going new and switching to electric - anyone with hands on experience care to share their opinion? Boat lives on a trailer most of the time and fresh water washed after use. Thanks!
1977 23' Sceptre
Old 07-24-2021, 08:51 AM
SeacraftErik SeacraftErik is offline
The Bolts are legit! Simple to wire as well!
Old 07-24-2021, 09:09 AM
I'm going to guess that even though the boat is kept on trailer you probably have it close to the water and the salt air. I would check the wiring and maybe get a new switch before writing off the pump. My joystick control was shot and the wire connections corroded. I got the toggle /paddle switches and replaced the wire harness and still had to solder wires, but the tabs are still hanging in there.
Old 07-24-2021, 01:29 PM
I hear what you're saying Bump, but the tabs haven't worked since I bought the boat over 10 years ago, and the troubleshooting I've done so far hasn't raised a peep out of the pump. The boat actually runs pretty well without them, but I'm thinking I can probably keep it on plane at slower speeds with them, and give me some trimming options on bumpy days. I was thinking about reusing the tabs themselves, but installing a new rocker control switch with the position indicator LEDs and getting the Bolt electric actuators.
1977 23' Sceptre
